Trunk-Recorder Error?
bburkett
MINERAL POINT, PA
I have been running Trunk-Recorder for a couple days and audio has been perfect! Working much better for me than SDRTrunk.
That said, I have received this error several times:
[2023-12-31 13:39:22.145847] (info) [icorrs] Started with Control Channel: 854.137500 MHz
[2023-12-31 13:39:22.146878] (info) P25 Trunking two-stage decimator - Initial decimated rate: 100000 Second decimated rate: 25000 FA: 6250 FB: 12500 System Rate: 1600000
[2023-12-31 13:39:22.153920] (info) P25 Trunking ARB - Initial Rate: 1600000 Resampled Rate: 25000 Initial Decimation: 16 System Rate: 24000 ARB Rate: 0.96
Allocating 15 zero-copy buffers
[2023-12-31 13:39:22.875892] (info) [icorrs] Decoding System Site RFSS: 001 SITE ID: 010 (001-010)
[2023-12-31 13:39:22.875961] (error) [icorrs] 0C TG: 2268 Freq: 0.000000 MHz Not Recording: no source covering Freq
[2023-12-31 13:39:23.939529] (info) Error - can't set XOR Mask for TDMA
[2023-12-31 13:39:25.983199] (info) [icorrs] Decoding System ID 152 WACN: BEE00 NAC: 150
[2023-12-31 13:42:21.215417] (info) [icorrs] 2C TG: 2268 Freq: 855.812500 MHz Starting P25 Recorder Num [6] TDMA: true Slot: 0 QPSK: true
[2023-12-31 13:42:26.867134] (info) [icorrs] 2C TG: 2268 Freq: 855.812500 MHz Unit ID set via Control Channel, ext: 641113 current: -1 samples: 0
[2023-12-31 13:42:30.386587] (info) [icorrs] 2C TG: 2268 Freq: 855.812500 MHz Unit ID set via Control Channel, ext: 71177 current: -1 samples: 0
[2023-12-31 13:42:43.019661] (info) Currently Active Calls: 1
[2023-12-31 13:42:43.019690] (info) [icorrs] 2C TG: 2268 Freq: 855.812500 MHz Elapsed: 22 State: recording
[2023-12-31 13:42:43.019730] (info) [ 6 ] State: idle
This occurred right after startup and not after that.
My config.json file contents:
"ver": 2,
"sources": [
"center": 854791700,
"rate": 1600000,
"ppm":-1.2,
"gain": 48,
"debugRecorders": 0,
"digitalRecorders": 6,
"driver": "osmosdr",
"device": "rtl=0"
"center": 856100000,
"rate": 1600000,
"ppm": -1.2,
"gain": 48,
"device": "rtl=1"
"center": 857408300,
"rate": 1600000,
"error": 0,
"ppm": -1.2,
"gain": 48,
"lnaGain":15,
"device": "rtl=2"
"systems": [
"control_channels": [854137500,857012500],
"type": "p25",
"talkgroupsFile": "icorrs_talkgroups_12-31.csv",
"audioArchive": false,
"callLog": false,
"recordUnknown": true,
"shortName": "icorrs",
"modulation": "qpsk"
"captureDir": "/home/bob/dockers/trunkrecorder/recordings/",
"plugins": [
"name": "rdioscanner_uploader",
"library": "librdioscanner_uploader.so",
"server": "http://192.168.0.53:3001",
"systems": [{
"apiKey": "c9570601-8a01-43eb-b3b4-6b6339151be1",
"systemId": 152
Any ideas on cause? I couldn't find anything in my searches.
Also, I am running 3 RTLSDR v3 and I haven't been able to find a list of applicable parameters that I can use in my config.json file. So far just testing to find ones that work. Can anyone point me to a list of parameters specifically for the RTLSDRs?
One last one: What is acceptable Hz error? ...and should it be changing?
Thanks for you time!
~Bob
Kingscup
It looks like the error could be that frequency that was used was outside of the range of the SDR. You might need another SDR to cover that frequency.
tadsmith
On startup, it needs to wait until it receives a specific control channel message to identify the frequency band plan. It can take a second.
