broken link
QDP2012
at the bottom of the scannercast setup instructions
RR Live Audio Broadcasting Software - The RadioReference Wiki
their is a feed does not go anywhere and said contact admin
http://forums.radioreference.com/live-audio-administration/
thanks for any help.
stan
Good catch. The forum was renamed after Broadcastify was created, and the link on the above page apparently was not updated with the new link.
The dead link should be updated to be:
Code:
http://forums.radioreference.com/broadcastify-live-audio-administration/
EDIT: You can click the above link to navigate to the Broadcastify/Live Audio forum and post a message to the Broadcastify/Live Audio Administration team.
EDIT 2: If you are trying to contact another Feed Provider, you might wish to use the Broadcastify/Live Audio Listener Support Forum. The other link above is where Feed Providers contact Administration.
The Wiki page you mention above is locked/restricted, which means only someone with Wiki-admin privileges can update it.
Thanks for pointing out the link problem.
Hope this helps,
AK9R
Staff member
Super Moderator
Central Indiana
Fixed. Thank you.
