So I picked up a used Pro-649. It powers up, display works, key beep works, I was able to do a factory reset, I can program in channels, and the volume and squelch both seem to function. But it isn't able to hear anything, not even the local weather station. My first thought was antenna, so I tried a new one, and opened it up and checked the antenna connection (which seems fine). I also programmed in one of the FRS channels and keyed up an FRS radio a few feet away, thinking it should pick THAT up even without an antenna. It did not.
If I turn the squelch down, I get "static" as I would expect, but nothing else.
Anyone have any suggestions as to what else I could look for? I'm thinking that the front end is probably blown out on it. I don't think it would be worth fixing, so it may just go in the electronics recycle bin.
Thanks.
Thanks.
