Broward County
wolfen1202
margate
I live in Broward and can not seem to loacate broward sherrif -north transmissions. I have programmed bcd996p2 scanner with ps25 from rr thru freescan. Any ideas? Appreciate any assistance. I want to listen to Margate and Coconut Creek. What I got from rr and entered is not same as is coming from Broadcastify.
APX8000
Sarcastic Member
AES-256 secured
What system did you enter ? Are you receiving any other Districts ? Any other transmissions ?
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
I use a BCD996P2 scanner to monitor Broward County P25 system for now, it works OK-ish if you accept the garbled audio. I'm in east Oakland Park so YMMV depending on where you are listening. I had to set the P25 Threshold manually to 8 so it doesn't try to hunt around and that seemed to help clean up the audio a bit.
Once I can knock off the first few hundred items from my important to-do list I'll start on setting up an SDR system to monitor that system for my Wild Feed.
APX8000
Sarcastic Member
AES-256 secured
Remove Coral Springs / Fort Lauderdale / Plantation. That is a different system. As Jim said, use Broward P25. Use ONLY Site 1, delete the other sites (backup and Alligator Alley). Once you are locked on that system and site only, post results.
wolfen1202
margate
Results excellent. Am now receiving Margate. Thanks so much!
Bote
know-it-all
Unless the scanners have the ability to differentiate the different system IDs, it makes no sense for RadRef to list them all in the same table like that. It's not helping things. This is not the first time such a problem has been reported here.
tvengr
Well Known Member
Baltimore County, MD
Please check your PM.
GTR8000
NY/NJ Database Guy
BEE00
Systems that share a core are listed together, such as Coral Springs/Plantation/Fort Lauderdale (544). That system has no bearing on the county system (997), and they are obviously both listed as separate systems in the RRDB. The three sites under the 544 systems are clearly labeled, as are the talkgroups categories. What exactly is this "problem" you're talking about? What are you referring to when you say they are 'all listed in the same table'?
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
please continue discussions about Broward in the master thread:
