BT Connection Cable
Ensnared
Waco, Texas
I lost a BT connection cord. Please: a) Tell what type of cord I am looking for; b) where is a good place to find one.
hexagon_keyhole
Sacramento, California
Could it be something like this? Found this on Amazon for a 3-Pack:
Headphone 3-Pack AUX Headphone 3.5MM Extension Cable
I don't think that cable is the actual Bluetooth Transmitter, the cable is more of a pigtail that extends the transmitter so that it can be a little more flexible in placement. You could also be fancy and use a right angle hack to minimize it from jutting out too much when plugged into the scanner.
Ensnared
Waco, Texas
Thank you!
Actually, I found a perfect M-M that would work great; however, I did not know if the right angle shaft would seat well into the input.
Then, I found an even better one. I never realized it was so hard to find these atypical connections, M-M with flexibility. The BT came with two cables, the one you showed and a M-M version of the one you found. I am going to guess and just jump into the water. Hopefully, this will work out: https://www.amazon.com/Aukeer-2-Pac...locphy=9027473&hvtargid=pla-569780615497&th=1
