build DMR hotspot
braluca
I would like a DMR hotspot with LAN.
Is there any ready product with at least Raspberrypi 3b? It seems to me that all what I find are using Raspberrypi 0
I can also try to build by my own, I would like to avoid soldering, then problem is find MMDVM module with already female GPON connector
Waiting suggestions and ads
n2mci
Kingston, NY
You should be able to buy a RPi 0/2 with the headers installed. A RPi 3 b works great too.
If you want to keep the package (RPi / MMDVM) small, you can buy a USB micro Ethernet
adapter. (Dongle). Just be aware, all these dongles have the same Mac address and if
you try to use more than 1 of these dongles on your network, you have to edit a file to
Force/override the default Mac address to something else.
It's a simple edit in a file, I just don't remember what file off the top of my head. Again,
It's only for more than one dongle on your network.
I prefer to use the same size RPi as the MMDVM board. Mechanically they fit together better.
Hope this helps, Pete
NL5J
Kirbyville, Texas
ClearNode – Pi 4B – UHF – Store – Node-Ventures. Pricey but I couldn’t be more pleased with this setup and their support. I have the HamVOIP version.
