You need to check out the Database on this website and program your PSR to scan then Trunked system. You will be able to hear almost everything, HRM POlice / RCMP, HRM Fire, EHS, DNR, .... everything. You have a pretty expensive and quality piece of equipment and judging by your last 3-4 posts, you seem to be having alot of difficulty in using it and programming it to get use of its full potential. Freescan is good software and will actually allow you to import the correct information directly from this website. Do alittle reading and research on it and you will get plently of enjoyment from your scanner.
