Bye bye sunspots
k9rzz
Milwaukee, WI
Start stringing up that low frequency longwire you've always dreamed about!
Say Goodbye to Sunspots? - ScienceNOW
Scientists studying sunspots for the past 2 decades have concluded that the magnetic field that triggers their formation has been steadily declining. If the current trend continues, by 2016 the sun's face may become spotless and remain that way for decades—a phenomenon that in the 17th century coincided with a prolonged period of cooling on Earth.
Sunspots appear when upwellings of the sun's magnetic field trap ionized plasma—or electrically charged, superheated gas—on the surface. Normally, the gas would release its heat and sink back below the surface, but the magnetic field inhibits this process. From Earth, the relatively cool surface gas looks like a dark blemish on the sun.
Astronomers have been observing and counting sunspots since Galileo began the practice in the early 17th century. From those studies, scientists have long known that the sun goes through an 11-year cycle, in which the number of sunspots spikes during a period called the solar maximum and drops—sometimes to zero—during a time of inactivity called the solar minimum.
The last solar minimum should have ended last year, but something peculiar has been happening. Although solar minimums normally last about 16 months, the current one has stretched over 26 months—the longest in a century. One reason, according to a paper submitted to the International Astronomical Union Symposium No. 273, an online colloquium, is that the magnetic field strength of sunspots appears to be waning.
Since 1990, solar astronomers Matthew Penn and William Livingston of the National Solar Observatory in Tucson, Arizona, have been studying the magnetic strength of sunspots using a measurement called Zeeman splitting. Named after the Dutch physicist who discovered it, the splitting is the distance that appears between a pair of lines in a spectrograph of the light given off by iron atoms in the sun’s atmosphere. The wider the splitting, the greater the intensity of the magnetic field that created it. After examining the Zeeman splitting of 1500 sunspots, Penn and Livingston conclude that the average magnetic field strength of sunspots has declined from about 2700 gauss—the average strength of Earth's field is less than 1 gauss—to about 2000 gauss. The reasons for the decrease are not clearly understood, but if the trend continues, sunspot field strength will drop to 1500 gauss by as early as 2016. Because 1500 gauss is the minimum required to produce sunspots, Livingston says, at that level they would no longer be possible.
... (cont.) ...
zz0468
Banned
But hang on to your ten meter antennas. There's always sporadic E. And even during the deepest, darkest part of the current minimum, I was able to work Asia, South America, and most of the U.S. on ten meters.
On the other hand, 160 is a FUN band!
ridgescan
San Francisco, Ca.
No you will be in SWL hell. No sunspots equal no DX.
Sorry for my confusion-well that definately sucks. I gather from zz0468 that the higher frequencies won't be affected? All the fun stuff is on the lower end. Well it will be a challenge to see what we can get compared to now. Are we at a solar minimum right now? If so, conditions have been pretty good IMO.
a29zuk
SE Michigan
Yes we are at a solar minimum right now. The problem is that the cycle should have been on an upturn by now but it is staying at a minimum. In years past, during the higher levels of solar activity, many broadcasters would move to higher frequencies. It was not unusual to listen to Radio New Zealand, Radio Australia, and the BBC every evening on 21mhz. Even some would broadcast on 25 mhz. Many more utility stations would use 16 and 18 mhz and higher. What zz is saying is even though the sunspots are low, occasionally sporadic E will flare up and on certain days the higher frequencies will be active.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hardly, if the stuff reported in the NASWA and DXLD yahoo groups are any indication. With the low sunspots, and moving into the fall season, the low bands will be the place to be. But as mentioned previously, sporadic E (sometimes also written as Es) can happen almost any time.
If you're chasing DX on 60 or 90, the antenna you are using becomes even more important. From Northern California, Asia and Indonesia are real possibilities.
73 Mike
zz0468
Banned
What I'm saying is, even without sunspots, the higher bands occasionally open up. Just not as often, or as long.
k9rzz
Milwaukee, WI
+1
Sunspots - sunsmots. You just have to adjust your radio habbits to the conditions.
There's always DX to be heard at any given time, maybe not on your favorite band, but there's always something to chase - somewhere.
Saint
Fort Erie Ontario Canada
Sunspots
+1
I agree the easiest way to find out if the band is open is just tune into it and try it, if you want to know if it's raining out look out the window, I have always did a search through all the bands anyway to see what I can pick up and this is the best way to find the best band.
Steve
CalebATC
Blairsville, Georgia
I actually did a news article in school about this. Sad to see, I was looking so forward to getting on HF and getting some extremely long DX QSO's.
Too bad, anyway, there is always some openings. I guess they will keep getting rarer and rarer. Time to get out your 10 meter SSB radio!
k9rzz
Milwaukee, WI
Huh?
I can almost guarantee you that I could jump on 40m CW on any given night and work someone in Europe or South America. Very late at night I could raise someone in Australia or New Zealand. A small amp. worth 300 - 400 watts would help of course, but even with 100w I'm sure I could do it, sunspots or not.
