Calhoun county
GA
Does anyone know if Calhoun county Ga can be programmed to listen only on a baofeng dm32uv
tvengr
Well Known Member
Baltimore County, MD
www.radioreference.com
Gordon County, Georgia (GA) Scanner Frequencies and Radio Frequency Reference
Scanner Frequencies and Radio Frequency Reference for Gordon County, Georgia (GA) www.radioreference.com
That is for Gordon County. OP wants Calhoun County. Calhoun County, Georgia (GA) Scanner Frequencies and Radio Frequency Reference
GA
I finally got my hands on an xpr2500 now to figure out how to program for trunking so I can listen to the county regular DMR I got figured out but not the trunking aspect I’m new to all this digital stuff.
  • Haha
Reactions: RRR
GA
What does LCN 0 mean and LSN -1 mean and how do I program it in the radio? I. Keep seeing LCN is logical color number online but not sure if it’s true. Also can anyone explain how to program a capacity plus system to a radio? Do I program each channel in a zone then just a scan list to be able to listen only? Or is it far more complicated? Amy help would be appreciated!
tvengr
Well Known Member
As inexperienced as you are, you would be better off with a scanner. You need to know exactly what you are doing to keep the radio from transmitting, unless you want to live in a gated community.
GA
I’ve got a good bit of local DMR and analog departments in there and have it set to RX only. The radio was given to me and I was just tinkering around with it. I’ve got several other mobiles but with mainly weather in them. I greatly appreciate all the advice and knowledge y’all have shared!
