calif fire is on fire
Mick
Western U.S.
Here's the specific info on FRS usage from the FIRESCOPE Radio Comm Guidelines, Appendix A, July 2007:
"Family Radio Service (FRS) radios are prohibited from use on Federal and State of California incidents."
trooperdude said:
OES HIGHLY discourages this, but everybody learned after Katrina that they were great for close in comms and are pretty much disposable.
Also check the MURS channels.
Some departments are said to program them into their HT's.
brandon
SoCal
You were probably hearing the stringers on 462.650R rather than firefighters.
brandon
SoCal
mikeh said:
Couple more freqs from San Diego
168.775 Command Repeater is not listed as NFIC or BLM
this is new freqs what kind of traffic are you hearing
this could be intesting
The signal is full strength from my scanner located in southeast El Cajon.
Hearing phrases such as:
"Ramona structure group"
"Escondido structure group"
"Witch communications"
Talked about Hwy 78 and Ramona. Units refering to the channel as "Command". Unknown if this is a simulcast of another freq. So far I've not found one. There is also a longer squelch tail when the user finishes keying up.
mikeh
fremont calif
[someone forgot to tell some in calif
QUOTE=Mick]Here's the specific info on FRS usage from the FIRESCOPE Radio Comm Guidelines, Appendix A, July 2007:
"Family Radio Service (FRS) radios are prohibited from use on Federal and State of California incidents."[/QUOTE]
mikeh
fremont calif
Update Fire List
Are being used
UPDATE FIRE LIST CAN ANYONE ADD ANYTHIHG NEW TO THIS LIST
118.525 TFR
119.975 Air to Air
122.190 may be Camacho TFR ??????????
122.225 Canyon Country/Buckweed Fire TFR
122.925 CDF Secondary
123.775 Helo air tac big bear
123..000 falbrook TFR
123.200 fallbrook TFR
123.975 Air Attack Base
122.425 helo ops
125.775 TFR
126.7625 tem tower unknown ?
126.700 this is a tem tower freqs set up at tem fields
128.175 Harris Fire TFR
128.475 Irvine/Santiago Fire Air Attack TFR
130.200 Air Tactics 2
131.575 Lake Arrowhead/Slide Fire area TFR
132.000 tankers unknow
134.875 Castaic/Ranch Fire TFR
135.575 Witch Fire TFR, S.D. Co.
135.975 Malibu Fire/L.A. Co. Air Attack, Canyon Fire
136.025 air to air unknow
136.075 TFR
136.125 TFR
136.150 TFR
136.400 Air to Air
140.900 Travel channel, Point Mugu Naval Air Weapons Station Fire
Dept., OC to Seal Beach NWS
151.085 Or. Co. Access Channel simulcast with TG 2704
151.220 CDF Air/Ground
151.265 CDF Command 2 103.5 pl
151.280 CDF Air Tactics 4
151.295 CDF Air Tactics 5
151.310 CDF Air Tactics 6 "Santiago Air Attack"
151.340 CDF Command 3 103.5 pl
151.355 CDF Command 1
153.755 Travel Net
154.265 White 2
154.280 White 1
154.295 White 3
154.400 Air to Ground La county
156.075 CALCORD (used as a travel channel driving through Or. Co.)
159.345 CDF Tac 18
163.100 Region 5, shared use "Helibase"
164.150 R5 Project/Fire
164..9875 new fire channel
166.5625 South Ops input to 164.9125 link w/415.525
166.675 NIFC Air Tactics 1
166.775 NIFC Tac 6
166.6875 Air to ground tankers
166.9625 Air to ground "Big Bear Helibase"
167.100 NIFC Command 5
167.1375 NIFC Command 9
167.950 BLM Air to Ground Net "Canyon Air Attack"
168.050 NIFC Tac 1 Lake Arrowhead area
168.100 NIFC Command 2/170.45
168.200 NIFC Tac 2
168.300 new fire channel Lake Arrowhead area
168.350 Region 5, shared use. Common user
168.550 BLM Air
168.600 NIFC Tac 3
168.625 Airguard simulcast on 415.550
168.650 National Flight Following "En route Stable Fire" "I'm a C130"
"Switch to 172.475"
168.6125 NIFIC COMMAND
169.000 Travel channel
169.125 Calif. Fire Travel Net
169.150 Air tactics 2
169.200 Air tactics 3
170.000 FS Air/Ground
170.475 unknown channel name
170.5375 air to ground
171.125 new fire channel
171.1375 air to air tankes
172.275 Air Attack, Air to Ground "El Cariso" "Ranch"
172.350 new fire channel
172.475 Air Attack
173.775 Santiago Air Ops, Or. Co.
173.8125 air tankers
173.9125 Region 5 Tac 4
414.650 Command Logistics 1
415.525 South Ops w/164.9125/166.5625
415.550 Airguard simulcast on 168.625
417.800 Logistics 7 Lake Arrowhead area
172.2750 CSQ Air Tac? Mentioned Fillmore
168.3500 CSQ Mention of Cedar Camp.
166.8250 CSQ Referred to as Command, Air Tac was shutting down the airshow due to the smoke, Hwy 18, Grass Valley Operations, repeater both sides heard
169.9500 146.2 Simplex
136.4000 AM Victor freq given over the air on another frequency
415.5500 103.5 Talking about San Bernardino tanker base and heard "Ryan Tower"
173.9625 CSQ Simplex (scratchy from my location)
166.6750 CSQ "On Air Tac"
172.2250 156.7 Probably BDF Admin Net but had different tone than normal.
168.2750 85.4 Simulcast of CDF Monte Vista 151.190 freq.
169.5375 Fire operations repeater. Called "Command"
170.3875 Air Tac, mentioned Hwy 76 and Witch Fire
172.475 "south of us on the Witch Fire"
168.700 Fire traffic
163.5625 US National Guard, Echo callsigns
170.0125 Fire comms repeater, talking about Potrero, Harris Fire
170.450 talk about tankers and retardent
170.9125 P25 encryption
170.0625 Border Patrol running license plate number
170.725 P25 encryption
167.475 P25 encryption
171.425 Air Tac, sounded like they said "El Monte"
172.8125 fire traffic "helco" callsign
168.350 fire traffic (weak)
414.650 fire related traffic. called "Command" by units
415.450 fire related traffic
415.500 OM talking to unheard party
168.625 Air tankers ? Freq listed as Air Guard
168.700 Fire traffic (NIFC Command 1)
170.450 talk about tankers and retardent (input to 168.10 Command 2)
171.425 Air Tac, sounded like they said "El Monte" (input to 168.75 Cleveland NF)
168.350 fire traffic (weak) [Region 5, Shared Use, Common user]
414.650 fire related traffic. called "Command" by units (Logistics 1)
415.500 OM talking to unheard party (Logistics 3)
168.625 Air tankers ? Freq listed as Air Guard (Airguard, simulcast on 415.55)
P25 ENC is probably Border Patrol but the freqs didn't ring a bell so I wrote them down. I know the president was in town too.
scannerboy02
UHF, lol
HARRIS INCIDENT
MEDIA RELEASE
Release Date: Friday, October 26, 2007 11:00 a.m.
Harris Fire Information Line (619) 449-1462
________________________________________________________________________________
For All Media Aircraft
Due to the complexity of the aerial operations involved in the San Diego wildfires, we ask that any media aircraft entering the TFR’s surrounding the incidents contact the corresponding Air Tactics Aircraft on the following UHF frequencies. This is in place for the safety of all involved; civilian and fire.
Harris Fire:
136.150
128.175
136.075
118.525
Witch Fire:
135.575
122.225
Poomacha:
136.1250
For additional information please contact the Harris Fire Information Line 619-449-1462.
____________________________ ______________________________
Air Operations Branch Director Safety Officer
- END -
168.775 Command Repeater, full scale
171.5375 "there is a big flare up on the back of the ridge" Referred to as "air-to-ground"
415.225 talk about surveying the road again, "on Admin Net Tone 5", probably relay for Cleveland NF
Somehow I missed this thread during all the action. Now I'm laying on the couch feeling punky and the temperature outside might get above freezing today, so I'm not anxious to get up and do much. I'm getting my first comprehensive look at RR in months.
Lots of good information in these lists. This is one of those RR threads I'm going to print and refer to when I'm around large incidents in the near future. I can no longer get frequency information through the Forest Service like I used to as it is now labeled "for official use only." That is now being defined in such a manner that retired employees like myself, who logged 5500 hours on wildland fire incidents (about 2.5 working years), are excluded from "official use." I'm now forced to grovel around in search mode like everyone else, snivel, snivel. Since the narrow band/digital capable requirements for new radios in the federal government were put in place in 2005 lots of new air to ground, tactical, and command frequencies have been popping up. As I understand it the first seven command, tactical, and logistics frequencies are still fixed and have not changed. As far as I know anything that is mentioned as command, tactical, and logistics 8 and above are assigned to incidents based on need, available frequencies, and use by other agencies and incidents. This is similar to the long standing procedure of assigning unique air to air frequencies from an annual list of frequencies given the 11 Geographical Coordination Centers such as "South Ops" by the FAA and assigned to individual incidents by those centers. I would bet that they just call them "Command 8" and etc. just to distinguish them from the other seven programmed into all the field radios on a full time basis. I would suspect there is not a permanent list that shows a Command 8, 9 or above, but I could be wrong on this. I took a look at the program of a new digital radio assigned to a current Forest Service employee friend of mine and it only had the first seven, so this is one reason I think anything from 8 and above is a temporary situation. The downside to this is that every radio brought from a home unit to an incident has to be programmed with these 8 and above frequencies rather than dialed in by arriving units, which is something the larger memory radios were eliminating.
As for the use of 415.550, this is the down link for most National Air Guard remote bases in California. The up link would be 9 MHz's lower or 406.550. I'm not sure if all the remote bases have the up link repeated on the down link, a practice that used to be fairly standard before the big system replacement work done after the 2005 narrow band mandate.
Those are some general comments and now for some specifics.
168.775 is in use by the Forest Service all over the country for use on individual National Forests. It is the Fire Net on the Sequoia National Forest, the Forest Net on the Tahoe NF, and the input to the Forest Net on the Prescott NF in Arizona. There are more but these are the closest. Is the Forest Service pulling a CDF and recycling their Forest (local) nets for use as commands and tacticals in other areas? This would make sense as they usually get exclusive assignments of their frequencies for the U.S. or at least west of the Mississippi.
168.300 is the BLM's California "Scene of Action" frequency. It isn't a "new" frequency or something unique to fires in the San Bernardino Mountains. They were probably using it as a tactical on an incident there because it is already programmed into almost every wildland fire radio in California.
163.100 and 168.350 are shared frequencies for the entire federal government. Federal wildland fire management agencies do not have an exclusive assignment for them. They are sometimes called (officially) the federal government's "wide area itinerant frequencies."
168.550 used to be the BLM's air net, something that the 168.625 National Air Guard used to be called. During the first part of my career air net was used for everything, air to ground, air to air, air dispatch, flight following, and even as an intercom between nearby National Forests. The BLM had a similar setup. Now 168.550 is often referred to as "ICS call-up" or an initial contact frequency for units arriving on an interagency incident. It is also used as an air to ground for smoke jumpers, be they BLM or Forest Service.
173.9125, 173.9625, and 173.9875 were assigned as tacticals for the Forest Service in Region 5 (Pacific Southwest Region of the USFS) sometime in the 90's or maybe late 80's. As Tacs 4-7 did not exist as such in the NIFC cache radios at the time they were given these numbers. Once the commands, tacs, and logistical frequencies of the BLM and USFS were combined to form the National Incident Radio Support Cache Tacs 4-7 came into existence. Now these are called R5 Tacs 4-6. It would make more sense to call them R5 Tacs 1-3 now as calling them Tacs 4-6 could imply that there are an additional three called R5 Tacs 1-3 right now, but what would I know.
172.350 is a simplex, mobile, and tactical frequency assigned to the Los Padres National Forest. I think they were given this and 170.475 years ago to construct a second repeater net on that Forest, but decided they needed a couple of simplex frequencies somewhat unique to that Forest more than they needed a second repeater net. I always maintained that every Forest needed a Forest Net that everyone stayed on during average conditions, and an Admin Net for units to have more extended conversations on such as wilderness rangers and recreation personnel calling a ranger station or each other for weather information, recreation conditions, road and trail conditions; and the like. In addition I think they should also have a "fire command net" to be able to switch fire units to during multiple start conditions such as lightning storms so they don't have to take over the Forest net. But the people on the Los Padres didn't even seem to want a second net, so I guess my view of the situation is not widespread.
166.675 is National FM Air to Air Tactics 1.
You may hear air to air, air to ground, and command traffic on one of the Logistics frequencies. The logistical portable UHF repeaters are frequently used as links between command repeaters and to extend the range of VHF aviation frequencies (123.075 and similar). In my own fire experience I've heard them used to extend the coverage for incident helibases on 123.075 more than any other use. I've also been on some very large fires where one portion of the fire was on one command channel, say Command 1, and another portion of the fire was on Command 3, this being necessary due to the size of the fire and its topography, in addition to having some areas of overlapping coverage between repeaters on each command. They wanted everyone on each channel to hear all the same traffic, so they used UHF repeaters to cross band link the two VHF repeaters so that traffic on either repeater would be heard by both VHF repeaters. Once an incident grows large enough to employ two or more Type I incident teams, with an Area Command Team in charge of the entire fire, each team usually is in charge of a particular "zone" on the fire and each zone has their own command channel. The thing that should be remembered is that the Logistic net frequencies can be employed for all sorts of purposes. Traffic on the Logistic net on an incident is usually not very heavy and the repeaters don't have to be located in a real high location that interferes with other incidents leaving the 7 Logistic channels open for all sorts of interesting uses.
This is one of the best monitoring reports I've seen for a large incident and group of incidents. If enough people do this over the upcoming years we might be able to see common information from year to year to determine if there are permanent assignments for some of these newly assigned frequencies. When state and local agencies are required to use narrow band we are really going to see a lot of new stuff appearing overnight. APCO frequency coordination lists and the FCC database are already starting to show some, but around 2013 (the current narrow band required date I believe) we are going to be caught flat footed unless we prepare.
Thanks for providing this link. Homes burning without affecting the surrounding vegetation was documented as a significant factor. The fire spread from house to house, not because the surrounding fuels burnt, but because the construction materials in the homes resulted in ignition that carried from structure to structure. The same factor was present on the Angora Fire in the Lake Tahoe Basin. Fuel treatments are important, but construction materials play a large role that caqnnot be ignored. Areas of private land where fuel treatments were in place prior to the fire made a significant difference as well.
