Calls platform; connection broken
KC3AWP
Lycoming County, PA
I noticed my calls node was deleted the other day due to inactivity. Odd because nothing was touched int the year or so it was running. Resubmitted for a new node and reset up everything how it was and no activity is being uploaded. I looked into the logs and found this multiple times:
2024-12-24 14:31:17,452 - DEBUG - Starting new HTTPS connection (2): api.broadcastify.com:443
2024-12-24 14:31:17,517 - DEBUG - Incremented Retry for (url='/call-upload'): Retry(total=1, connect=None, read=None, redirect=None, status=None)
2024-12-24 14:31:17,517 - WARNING - Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1091)'))': /call-upload
2024-12-24 14:31:17,517 - DEBUG - Starting new HTTPS connection (3): api.broadcastify.com:443
2024-12-24 14:31:17,587 - DEBUG - Incremented Retry for (url='/call-upload'): Retry(total=0, connect=None, read=None, redirect=None, status=None)
2024-12-24 14:31:17,587 - WARNING - Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1091)'))': /call-upload
Literally nothing has changed since ive started this node. I can ping api.broacastify.com with no issues. Ive deleted VoxCall and started fresh but still the same error. Any help? Ive quadruple checked my API key as well.
KC3AWP
Lycoming County, PA
These things take time to be noticed by people who know about them, you need to remember it is still the Christmas holiday and many members aren't active this week.
Yeah, I realized that i posted Christmas eve after the fact. I don't expect an official answer immediately. The "Anyone?" was for for the almost 100 viewers. Being as there's over 600 other call nodes up and running, its probably something on my end. Just wasn't sure if anyone already ran into this before and its something simple I'm overlooking.
KC3AWP
Lycoming County, PA
Just for info, the computer running the feed is a Windows 7 pro SP1. Im working to see if i can get SP2 on it.
blantonl
Founder and CEO
Dallas, TX
