Caltrans
SYZ1165
hello, I am trying to monitor Caltrans district for North and south. I am using a SDS 100 SCANNER for the first time. I use radio reference as a jumping off point and then went to Sentinel software and loaded district 4, but when I was finished and did write to SCANNER. I had a message come up saying nothing to scan. Has anyone else had this occur or am I doing something wrong?
mike619
You should go in the menu on the SDS 100 and in manage scan selection and look and see if your system in that list is on also in set quick key status system quick key look for the system you programmed by it's name what ever you named it like Caltrans and make sure it is turned on.
SYZ1165
I made sure that the items in the favorites list were turned on and that they were also downloaded in Sentinel software. I also made sure that they were turned on on the SDS 100 but when I went to Caltrans District four north or south on the scanner, said nothing to scan
