Last word.
Adding
all the frequencies on the license can cause issues, as has been previously posted, only the CC frequency is needed in the site for the scanner to work. By including frequencies that will
never be a CC but also carries traffic of some/any sort the scanner may linger looking for the CC on that frequency, it could even just be interference. That prevents you from getting actual traffic in that duration.
All those issues are mitigated by only including the CC (and SCC's if it changes frequently, depending on the system)
If only the active CC is entered/programmed; then the scanner only looks at the appropriate frequency and moves along, instead of looking at 20 frequencies that just wastes the scanners time hunting for the real CC. This applies to all BCDx36HP's and SDS scanners.. Just saying, Your right. You can do it anyway you want. I prefer to help the scanner out by removing all but the CC frequencies on the systems I monitor.
Your method is appropriate for sure when a new system is being built and the info is not yet known.
The Camden P25 is not one of those.
