saioke
- Joined
- Apr 18, 2010
- Messages
- 191
- Reaction score
- 85
So I have a Whistler ws1065, using an outdoor yagi pointed in the direction of some towers that I want to pick up on the Ohio MARCs System. Typically, I get 4-5 signal strength bars and the T symbol shows constantly when scanning the trunk sites. Currently, I just run wildcard pulling in whatever is in those areas. However, the issue I've been having is that a lot of the time, a tgid will appear as if someone's talking, but there's no audio. Sometimes, those same IDs will talk, and they'll be clear. Sometimes, those IDs will be garbled and cut in and out, but the signal strength never really changes from 4-5 bars.
I have each of these sites:
Vinton County: Allensville, Mcarthur, Indian Camp, Union Furnace and
Jackson County: Jackson, Camel Church
All in two separate Tsystems in two separate scanlists split between counties. My conventional channels are all in a single scanlist as well split away from the tsystems. One odd thing I've noticed under the Jackson site, is that the CC frequency "774.53125c" isn't even listed under either of the callsigns. I still have it programmed in the scanner, but this seems odd?
I have squelch set at a minimum, as low as I can without conventional channels staying active. Other settings are practically default, and I can't seem to decode the trunk towers at all when I turn on the att. Tried turning off digitalAGC as well, but that made no difference.
I'm not sure what I'm doing wrong, if I'm doing anything wrong. Some of those sites seem to have multiple callsigns listed, and some have more towers. I've heard simulcast typically doesn't use C4FM modulation but I've also read that it can. So, anyone think any of the sites listed above are simulcast and that's why I'm having these IDs pop up that stay silent? Occasionally I'll see an ID pop up from another county entirely from the ones I've entered into the system so that kind've leads me to believe it may be simulcast?
