I'm currently in Ohio, and I came across this control channel while searching on the scanner that I can't figure out what it is. I use a Yagi so it's possible I could be picking up another county entirely but, at the signal strength that I'm getting, I'm thinking it has to be local. Viewing my county Vinton, as well as the closest neighboring county Jackson here on RR, I can't find this frequency listed at all. Oddly enough, I've also done a search on the FCC website and it came up empty, even if I search through ALL states. Surely this frequency should be listed on the FCC website at least, right? The frequency is - 771.58375 and I have included screenshots of my display.
Normally I would say it's a bug, but I have been picking up local talkgroups by programming this into its own TSYS. So, it has to be a real CC.
But I don' t know, I've also discovered 854.2875 which, from my searching, I've discovered it's a CC for my local electrical company AEP but, I don't know how that works because afaik it's on Phase 2, and my scanner only supports phase 1. That has to be a bug, right?
