I have been googling and looking for a clear cut understanding and have only found numerous, unclear understanding, to a issue I've started to experience today. I found the applicable filters that work on my two sites I monitor on the State of Colorado DTRS statewide system, or work the best so far. Today all of a sudden those filter settings are both not doing well at all, all of a sudden. So, I tried other filter settings as well, and it seems none of the filter settings are doing a very good job in helping signal and clarity and all leading to a fair amount of D-Error rates and horrible digital Garbled transmissions or whatever it's called.
The Issue that I believe is causing this issue today is the smoke in the atmosphere from the wildfires that is blowing in from other states, as it's really the only change in anything, at all, that I can logically assume would all of a sudden cause this. The smoke is really not thick per say, but lightly hazy in looking out. Just curious if anyone has a knowledge, and can affirm this thought or not, as if maybe this would be a reason for the worse audio quality I'm experiencing, as well as any other thoughts or expertise in what could lead to this type of situation. I have not changed anything or moved the antennas position as well.
