Can someone help me identify this antenna connector type?
Hello all,
Can someone help me identify this antenna connector type? I beleive it to be an (Reverse polarity) RP-SMA Female. I'm focused on identifying the antenna side of the device.
This antenna is for an Inrico IRC380 UHF model POC device, and im looking to purchase an aftermarket antenna.
Thanks in advance.
Yes I know these pictures arent the best. I have ordered the unit. It will be in my posession in a month or so (shipping from china) I will reply to this post or start a new thread when I receive item with better quality photos. Apologies.
Ubbe
Stockholm, Sweden
It could need an antenna that are made to do both GPS and 2G/3G/4G cellular as well as UHF and WiFi. I know that Motorola portables that have GPS needs a special antenna that handle both GPS and VHF/UHF. If you only are concerned about UHF then of course any antenna for that frequency band that fit the connector will do. It looks as if the antenna connector on the IRC380 are recessed like on a Uniden SDS100 scanner, so that the antenna cannot be to too thick at its connector, or fit a BNC adapter and use BNC antennas. But it is still unclear if it should be an antenna with standard male SMA or reverse male RP-SMA.
/Ubbe
dave3825
Suffolk County NY
Since they don't mention anything about the antenna, other than it makes the radio user friendly, probably best to call them. Hopefully they are user friendly as well.
dlwtrunked
Hello all,
Thanks in advance.
Looks like common SMA-M. Here is a webpage that might be of use
G7RUX
I have looked at the 380 in person and the UHF model in my hand had "standard" SMA connectors, not reverse polarity ones.
That said, it's a hideously expensive and poorly-made unit so I would avoid it personally.
