OK, first off - I have searched for the last 30 minutes, using different terms to try to find if this was covered before. If it has been it is buried in another thread and I didn't see it. The one I found that did address it basically said it magically just started working so that didn't help.
Here's the issue - I'm trying to register a 536 on my.uniden.com
I added the physical serial number but when I go to add the ESN so I can do the DMR upgrade...no good.
I enter all the digits (the last 9) and it gives me this error:
OK, let's go back and drop a digit. Nope!
Endless loop of back and forth with the same errors.
Someone else posted that they'd had this exact problem but they are the one who, when Paul posted a question in response, just said it started working for them and they didn't know why.
I've tried multiple times and, yes, searched for the answer here and haven't found it as of yet. And yes, I've entered it carefully, etc., etc.
If it's a simple fix then take it easy on me...I'm usually pretty good at this stuff but this one has me stumped and getting frustrated.
Check Sum passes. in Please go back by clicking your back button and enter a valid 8 digit serial number using integers.
You must enter 8 digits and only 8 digits for the scanner's Serial Number.
The ESN number you entered is not 9 digits in length. Please recheck your input to ensure that you have entered the last 9 digits of your scanner's serial number into both serial number fields.
Please go back by clicking your back button.
