DSDPlus Cap+ with 2 Airspys
Annunaki
Hi guys so I have pretty much mastered TIII systems with a dual receiver setup but I have discovered a 3 repeater Cap+ system nearby which I have now correctly populated in my frequency and site files.
The issue is this, when using the same dual setup that works perfect with a TIII system it does not seem to work correctly with a Cap+ system, I see the CC copies of FMPA/DSD switching between the rest channels/frequencys correctly but nothing happens on the VC copies of FMPA/DSD when voice is active.
It seems that the CC copies are doing the work for both CC and VC which I cant figure out why.
Any help would be appreciated.
Cheers
slicerwizard
Toronto, Ontario
Based on what's being reported in another thread, I would verify that both copies of DSD+ are connecting to the correct TCP ports.
Annunaki
Ports are fine as I mentioned TIII systems on the same setup work perfectly but Cap+ not.
Annunaki
Could someone show me an example of a Cap+ system in their frequencies file?
Annunaki
Actually I found this in Trunking.txt
Oh well...
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Example system: (sid in RRDB is 10126) - First Energy - Sammis Plant Trunking System, Stratton, Ohio - Scanner Frequencies
DSDplus.networks
Cap+,10126,"First Energy - Sammis Plant"
DSDPlus.sites
Cap+,10126,2,"Hilltop"
DSDPlus.frequencies
; FIRST ENERGY SAMMIS
Cap+,10126,2,1,451.2750,456.2750,1
Cap+,10126,2,2,451.2750,456.2750,2
Cap+,10126,2,3,452.0750,457.0750,3
Cap+,10126,2,4,452.0750,457.0750,4
Cap+,10126,2,5,451.2000,456.2000,5
Cap+,10126,2,6,451.2000,456.2000,6
DSDPlus.frequencies (alternative)
I have absolutely no problem trunking this system with FMPA / DSDPlus / single dongle. And, in a two-dongle configuration, I would expect the majority of voice traffic to always take place on the CC copy (because unless the system is very busy, all of the voice activity is on the rest channel, which is being followed by the CC copy of FMPA/DSDPlus. No big deal for me, shouldn't be a big deal for you.
If it were me, I'd use a single FMP*/DSDPlus to monitor any Cap+ system, as there really is no need to run two copies of each to trunk Cap+.
Mike
slicerwizard
Toronto, Ontario
Oh well...
That's very old information from the 1.101 files.
From Notes.txt:
DSD+ 2.183
Implemented single receiver mode Cap+ trunk tracking / voice following.
Implemented single receiver mode TIII trunk tracking / voice following.
DSD+ v2.10
Cap+ monitoring
Follow these steps to monitor / follow the rest channel and voice calls on a Cap+ system
a) select a network ID
Cap+ systems do not broadcast a network ID
If the system has been added to the RadioReference database, use its page number
Otherwise, assign the system a unique NID (9999, for example)
b) create an entry in the DSDPlus.networks file
Example:
Annunaki
DSDplus.networks
DSDPlus.sites
DSDPlus.frequencies
Mike
Thank you for the example
Are all Cap+ tx/rx systems separated by a 5mhz split? The only difference I notice from your alternative config comoatee to mine is that you have 5mhz splits set. Maybe this is my issue.
I really wish there was DB for allocated UK frequencys.
