Capacity Plus Scan List
APX8000XE
Classified
Hello,
I am trying to set up a scan list for the Cap + system I have in my XPR7580e, but under scan list it shows no available members. The radio works fine on the system, but I would like to add the capability of scanning 8 talkgroups. I am using CPS 2.0. Any help is appreciated.
KG4INW
Midlothian, VA
The Cap + equivalent of scanning is called the Flexible RX List. Look in CPS for enabling that and adding members to it along with turning it on or off (from menu or button press).
APX8000XE
Classified
Once that's done, the radio should be able to scan? Do I need to change anything in the personalities under the zone tab?
KG4INW
Midlothian, VA
I no longer have a Cap + system to test on but from memory, and pulling up a codeplug just now, that should be it. Technically, it's not scanning but will allow you to hear other conversations on the system and toggle it off when desired like scanning does for conventional (when not roaming of course).
APX8000XE
Classified
Perfect, thank you.
