i have a 2001 mkIV jetta which had a double-single-din stereo, with an aftermarket, single din stereo and a 3 gauge cluster panel in the extra din slot, and a pro-97 hardwired that sits perfectly and securely in the pop-out cup holders on the early mkIV Jetta/Golf's had. it used to clip to the cover for the sunroof motor, but the metal and plastic clips holding the cover there have broken off from the weight of the scanner and too many bumps on a light-track built suspension. i originally purchased the pro97 a couple years ago when i joined a fire department which operates on a 150mhz system with EMS and a couple of the surrounding town's emergency responders. this was before i realized all of the digital trunking going on in neighboring towns and over state communications.
i had been planning on installing a custom/home built car-puter in the double din area (mp3/GPS/OBDII+ECU monitoring+data logging, the whole deal). both of the stereo slots would be filled by a 7.5" touchscreen LCD with the hardware in the trunk, but the pop-out cup holders would block the screen enough where the screen would be useless. a base/mobile scanner would also be out of the question as there are no other places to mount the scanner, except in the glove box which is near the bottom of the list of what i would be willing to do, besides the fact the glove box isn't real big. the other option is to fabricate a bracket, or pay out an arm and a leg for a pop-out lcd display and have a base/mobile scanner in the 2nd stereo din.
then it hit me. install a scanner that allows for a computer interface control, mounted in the trunk along with the car-puter hardware. i was going to get a a door mount for the antenna and mount it off the trunk of the car. the addition of a scanner into the interface would just add to the coolness factor. i would also be able to balance in the volume of the scanner with the car radio. i have a small remote-control dial, comparable to a joystick, that allows for complex scripted macro's so i could fade in/out the scanner and radio with a simple input from one hand. it is very easy even while driving. easy as in easier than trying to dial a cell phone, adjust a setting on my scanner like lockout, or attenuation, or finding the song on an mp3 CD in the head unit.
how are the controls on mobile/base scanners that can be controlled by a computer GUI interface?
if you have experience with this would it just be easier to do a double din, stereo/scanner setup? or are the computer interface controls worth taking a look at?
this also opens the doors to multiple scanners if they can all be controlled with a PC interface, or remotely.
the area of Connecticut i live has a plethora of systems. i will be scanning a 150mhz analog system with repeaters in the 450mhz range, motorola II analog and apco25 digital trunking, P25, MPT-1327 and EDACS. and i would also need an antenna. my current pro97 barely cuts it with an extendable whip and rubber antenna. but i also take this scanner inside with me quite a bit of the time.
