cb antenna
Project25_MASTR
Monitoring
Texas
I've never actually played with the Lil Wil. Personally, I prefer the NMO-27 for my low band needs. 48" tall, rugged, light (weighs about as much as a 2 ft fiberglass antenna) and as such is more cost effective as it takes advantage of commonly available (and serviceable) parts. As stated on the nmo side of the story, the fact that NMO has pretty much been the defacto commercial antenna mounting system since Motorola introduced it in the late 1960's (replacing 3/8-24 in 30 MHz and up application) is only a testament to how reliable the design is.
If the antenna is properly tuned, the only real difference you will find in performance related to gain which really only results in a 3dB difference in most applications (in cb).
Clubguy
Which antenna brand do you prefer? I'm leaning towards a sirio turbo 5000, but am worried about the roof of my vehicle warping.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Project25_MASTR
Monitoring
Texas
Larsen. Won't warp your roof and looks like a commercial install.
Second favorite is a 10/11m antenna made by Tram/Browning (used to be called the penetrator).
A nmo solution would be the lowest stress.
Stick with an American brand that you can get replacement parts for. It'll save you money in the long run.
Antennas are governed by the law of physics. No one makes "magic pixy dust" for antennas that makes them work beyond the limits of physics. No manufacturer has a secret formula that makes their piece of metal sticking up in the air work better than someone else's.
When comparing similar antenna designs, the performance should be identical. Where you will see "claims" of better performance, it is either shady marketing, not comparing like for like dB numbers, or some odd "gimmick".
Stick with a known commercial antenna manufacturer. Larsen has been proving themselves for decades, and I've been using them exclusively in public safety environments for many years without a single failure.
A properly installed NMO mount won't stress your vehicle roof. A properly installed NMO mount won't leak, and can easily have other antennas installed if you interests change. Magnet mounts will damage the paint and just look amateurish. If you want an antenna to work properly, install it correctly, tune it correctly and maintain it correctly.
WRQK570
My wife and kids said i have to many radios!
Yankton, South Dakota
It is your preference, a good c.b. Antenna like a Wilson 1000 or firestick, or a k40 will do fine, hell a 102" whip is the best in my mind
Clubguy
How do you park your car in the garage with a 102" whip installed?
Clubguy
Car, SUV, truck, garage...etc.
madrabbitt
NM
He's from Slidell LA.
I know someone from 'round those parts.
I'm going to assume jacked up ford with camo fender flares until told otherwise.
