Serpentina
- Joined
- Apr 3, 2013
- Messages
- 1
- Reaction score
- 0
Hello, I am new to CB radios. I have always wanted radios from when I was a kid, and would go to radio shack with my daddy, and look at them, but they were over 100 dollars and I could never afford them.
Recently I came upon 2 used and quite comparable 40 ch CB radios. The Uniden PRO 501XL, and the Radio Shack TRC-502, used $30 for the pair. My best friend and I are planning to use them for when I go out for bike rides. I have set up the Uniden as the home base station, as it is missing its clips and microphone hanger so I couldn't attach it to my bike. The Radio Shack radio I made a super awesome custom paper battery tube (works better than I expected) to power the radio. I plan to use channel 6 mostly for my communication with him.
The problem came to not having any antennas and not having the money to spend yet another 30 dollars for a pair of antennas, that would push me over my limit on this project. I did quite a bit of research when I got the radios to figure out how to make antennas, but there was nothing about making short and relitivly portable antennas that I could find, not being an expert.
Last night I had a dream that showed me how to make an antenne for the radio, I believe its called a whip antenna. Basically I took the 106.5 inches the mast style antenna is in length and I divided it by 4. I took two coat hangers and straightened them out as best as I could. They are pretty straight but not any where close to perfect, I didn't think they had to be perfect. And cut them both down to 27 inches, that is from where I bent it to stick into the connector to the tip.
I don't have any fancy calibration tools, or even a capacitor or a ground wire attached, just the coat hanger sticking out of the back of it. And I took my bike out to test it. I was a little ambitious testing it at first at maybe 300 feet away. My best friend said he heard me a little bit but couldn't make out what I was saying. Only when I was about 50 feet away could we both talk back and forth. He may as well have just yelled out the window to me.
His station is stitting in the middle of the biggest window in my apartment.
What do we need to do to make this work at a better range... we were hoping at least 2 miles, but it would be awesome if we could do more like 8-10 miles.
We are litterally on a shoe string budget, and can only use what we have laying around, which is pleanty of 5 foot or shorter stranded copper wire, more than enough coax cable that he picked up at work when they upgraded their system, a radiator that we could use to ground the base station radio (but I didn't know if it would even do any good, so I haven't yet), and a LOT of time to get it working.
My thoughts are that its possible the antenna are slightly too long? My math told me 26.625 should be the length but I cut them to 27 because it was a lot of work, and better to start long than short. But I am not any where near an expert on this...
My other thoughts are to try to create an indoor dipole, but we don't have a lot of room for one, and I am absolutly no expert on installing one, let alone building one. It would have to work inside, since this is an apartment, and I don't have any wire thats 108 inches long.
What follows are pictures:
Serpentine's Radio Setup - Imgur (the whole album in case the img tags dont work below.)
This is the base station.
Here is a look at the length of the antenna, as best as I could with the lighting
Here is a look at the 90 degree bend where the whip goes into the antenna socket. (its not touching the ground)
Here is the portable radio shack radio
Front view.
Thank you for reading, and for helping me with this project! I am so excited to have radios that are even working at 50 feet, I know we can do better!
Thank you for helping me!
Front view.
