CB radio recommendations!!!
niceguy71
Massachusetts
Radio and amp should be powered directly to the battery and fused at the Battery if you are buying the red and black wire that is connected together, get 10 gauge and connect to both the amp and Radio. A good small amp for both the AM and ssb is the RM Italy KL-203. Put a small computer fan on the amp if you are a Ratchet Jaw. Wilson 1000 antenna magnet mount works well with that setup. dont forget to tune the antenna. Sometimes you may need to trim the antenna length. Put the antenna in the center of the roof. Get help if you can. Just my thoughts.
Buying a better radio like the Radioddity QT-40 would give him 40 watts of power 500 channels 10 scanable frequencies like police and fire and all be in one nice unit... adding an Amp to the Bearcat will work... but this is a nicer install and will give him all the power he needs
niceguy71
Massachusetts
Assuming those are on analog FM.
I was big into listening to scanners in the 90s I had one that would listen to cordless phones and cell phones... it held 400 channels so I had everything programmed in there within 35 miles of me.....
I learned a lot about humans and mental disorders with that scanner.... people are plain NUTS!!!!... the cell phones were quite an eye opener.
Turn it on at night and you learn everyone is cheating on everyone.... everyone is out stealing something. . The things the state police were talking about on their cell phones taught me they were worse than the people they were arresting... one guy bought a WantAd book..... in the 90s you could buy a weekly book of stuff for sale from tractors to firearms.... one crazy I listened to on his cell phone called every single person in the book.. said yup that's just what I'm looking for... what's your address .. ok I'll be there tonight to buy it.... he said the same thing to at least 500 people that afternoon .. . I had to put that scanner away as I could not look at people the same way after listening to how crazy people are.
So I have no idea what the police and fire use for signals anymore???? But many of my friends on the police and fire still keep an old Bearcats 210 going 24/7 in their houses... when I visit I still hear police and fire so I'm assuming my area has not changed since the 80's¿??
niceguy71
Massachusetts
I agree with this however as opposed to getting an amp.
If he got rid of that 980 and got a 40 to 80 amp radio with NRC would make a world of difference.
Just having the NRC would allow him to hear much further out than that 980.ever could. . Why put an Amp on when you don't have NRC . . Without NRC he may only hear people 5 to 9 miles away.... so why bother buying an amp
niceguy71
Massachusetts
station32
if you can return your 980SSB radio to Amazon... you could buy a 40 or 60 watt radio that talks all across the country and all across the world... they both have "NRC" Noise Reduction Circuit... here is a 40 watt 500 channel radio AM/FM SSB with NRC and it's only $149 bucks on Amazon Radioddity QT-40
what the NRC does is it gets rid of most of the background static... getting rid of that static allows you to hear people very far away..... without the NRC ( like on your Bearcat 980SSB ) without the NRC you hear so muc
h static you're lucky to hear people 6 or 7 miles away... all you hear is static... but the NRC gets rid of most of the static allowing you to hear voices for miles and miles... and if you can hear people that far away.. and have the 40 or 60 watts of power from owning a Radioddity QT-40 or a QT-60 you could easily talk to those people that are far away..... the 980 will never be able to talk and hear the same distances the above radios are capable of.
in this video I show what the NRC is able to do..... fast forward to 2:14
K9KLC
Southwest, IL
Yes Ii agree 100% with this train of thought and I thought that's what my post reflected. In this day and age, there's really little reason to run an amplifier behind such a radio, you can't talk to people you cannot hear.
K9KLC
Southwest, IL
In my area and many areas things are P-25 trunking now. I have 3 unication pagers and 2 other scanners to keep up with the analog (old style normal) stuff. I can 100% assure you other than if I needed for some reason to hear the weather band, the VHF stuff in that radio would do me absolutely 0% good. I cannot comment on the OP's area, nor yours.
kb2rgz
New jersey
I don't consider the Antone or radioddity radios BETTER. I have tried several of the Chinese radios with extra channels and problems with features or the radio changed frequencies because of the microphone issues. In my opinion. mileage may vary. I would try a good antenna and skip the amp. Study for your ham ticket, and if you still want to go mobile, Get a Yaesu FT-891 a solid 100 watt ssb radio.
slowmover
Fort Worth
Change the mic. I — for one — have no need of channel change except on the front panel thus it’s an automatic upgrade for me.
Otherwise the experience had by the great majority is that these new radios significantly change 11M performance expectations in mobile applications. Base stations also benefit, but the option of running outboard DSP or fancier (bigger) gear also weighs. Older radios can’t meet the clear signal capture distance or SSB stability.
One can add the $225 WEST MOUNTAIN RADIO CLEARSPEECH unit I used for nine years outboard of several AM/SSB units over 750k miles to clean up RX, but it won’t also change one’s TX to, “digital clarity”. The combination is such that — given best antenna system — old hands with 30-years experience can’t adequately describe what’s possible short of having used DSP in 11M themselves.
Hear, and Get Heard has new boundaries. Old radios miss from 1/3-1/2 of what it’s possible to accomplish, TX & RX.
I made a one-way 900-mile rental car trip with a Galaxy 86V connected to a mag mount antenna over two days. It was like being deaf given I knew what to expect where every step of the way. No wonder the complaints about moribund CB.
— If the OP has to stretch out his dollars then Best Antenna is where to put them after installing clean 12V power. Extension Speaker, next, then radio last is the order as these two require mount solutions which increase their price.
“Integrated NRC”, is the most important radio feature, today.
EAFrizzle
Bond. Ward Bond
SE de DFW
Over the past 40 years I've had a 148, an HR2510, an RCI-2950 and multiple 2970s, and my QT-60Pro beats them all without a question. The NRC makes a  big difference on transmit and receive. Assuming you're going to go with a good-performing antenna, you need to ask yourself how well you want the radio itself to perform. Is it just for occasional convenience or are you really getting into radio?
Biggest thing is that you want to be satisfied with your radio once you get it set up. Do your research and ask lots of questions. Get something you know you'll enjoy. Most of all, have fun!
niceguy71
Massachusetts
the Radioddity QT-60 and Anytone 5555 N II definitely have problems with the channel selector switch after a couple years... I always make sure I change channels from the mic.... the factory mic only cost $20 bucks... so if it wears out I'll buy a new one.
I've played with few Bearcat 980SSB radios.... 4 watts.... no NRC ... it's an ok radio and works fine.. it doesn't seem to hold a candle to the 5555 NII QT-60 on receive... my 5555 N II's can hear Europe daily... I don't ever remember hearing much on the Bearcats ... my friend that had a Bearcat 980SSB told me he would work all day long trying to get a long distance contact on ssb..... we were out to breakfast... so I said lets try my truck... my old President Grant got 5 or 6 people coming back to me from all across the country on the first try..... we walked over to his truck and tried his Bearcat 980... and heard no one coming back.... both trucks had a Tram 3500 CB antenna..... yes my old Grant had 27 watts on SSB and his bearcat had 12 watts......
but I don't think a 4 watt non NRC Bearcat 980SSB for $189.99 980SSB on Amazon
can hold a candle to the 40 watt 500 channel NRC Radioddity QT-40 for $149.99 QT-40 on Amazon
but we all have our opinions
station32
Augusta Me
thank you everyone for the info and side conversations I am more than familiar with proper installs of vhf uhf public safety stuff and different mounting techniques I am more interested in the antenna radio combination as I am in many areas of the the state I live in now Maine I have no cell service and am looking for a distant line of communications using the ionosphere as my repeater so a imported radio with a few more watts and an antenna that knows how to move them is what my interest is also money is not an issue I'm just not looking to spend boucou bucks if almost as good as a a bit more cost effective I travel the backwoods and north Maine woods a decent amount and it's hard to iff not possible to contact them over distance
Chris155
Southern Maryland
If I bought another qt60 or similar I’d spend a couple hours playing with it before opening the case and converting. My qt60 channel knob worked but wasn’t really right from the beginning, if I had paid attention I could have swapped it out through amazon no problem.
niceguy71
Massachusetts
The radioddity QT-40 with the Stryker SR-A10 is hard to beat for a mobile setup... the Radioddity QT-60 is a better radio. But difficult to use in a mobile..... the screen gets a glare on it and is hard to see. .. the push buttons are hard to use at night or while driving
Best deal is to buy the antenna from Stryker so they have a record of it for warranty work.... this is $79.99 plus $20.00 for shipping with a torn box... they sell them refurbished because the box is torn or crushed... NOTHING wrong with the antenna I have gotten dozens of people to buy them including me
Stryker SR-A10 for $79.99
The Sirio 5000 performer is a better antenna ... but not something to be driving in the woods of Maine with.... it's tall. REALLY tall... the base is 6 inches wide and will not fit between the ridges of many trucks... if you don't go near trees it would be great
after you get it all ser up come back and let us know how it's going.
slowmover
Fort Worth
My first post.
Two links.
niceguy71
Massachusetts
PS Station32
I didn't say that you have to modify the Qt-40 to work with the cb band. .. just youtube how to modify a Radiodidty QT-40 or a QT-60.... you just have to move a a jumper... lift it off and push it back on to a different set of pins
niceguy71
Massachusetts
Trust me Amazon doesn't care what's been done with the radio. ..they take everything back... I have an Amazon return center by me and they sell all the returns there. . I buy a lot of CB stuff... just bought a QT-40 for $ 103.00... they have everything there filthy clothing that has been worn... products that were used hard for 30 days and returned missing the box... missing the instructions missing all the accessories... they take it all back in any condition... so you can modify it and send it back if you don't like it... they just put it out on the tables in the warehouse for pennies on the dollar.... guys come 2 or 3 times a day and buy the stuff to put on Ebay
station32
Augusta Me
good to know ive done some research on qt-60 and qt-80 what is a good antenna to pair preferably a mag so I can take off my truck and put up on my 12 flat top mast while at camp
