CC only Edmond
WX5JCH
Banned
Elk City, Oklahoma
Greetings fellow Okies!
Does anyone know what plan I would use to program Edmonds 800 system as cc only. I don't see their frequency setup in any of the 4 plans listed below.
PL1 (plan 1): This plan is the most common. Use Plan 1 if the last three digits of ALL the frequencies in use end in one of the following three digits: 125, 375, 625, or 875 (example: 856.1125, 860.7375, 859.6625, 855.8875).
PL2 (plan 2): If the last three digits of frequencies are less than 860.000 and end in one of the following three digits (125, 375, 625, or 875) and if ANY other frequencies end in (000, 250, 500, or 750) use Plan 2.
PL3 (plan 3): If the last three digits of ALL the frequencies in use end in one of the following three digits (000, 250, 500, or 750) use Plan 3.
PL4 (plan 4): If the last three digits of frequencies are less than 866.0000 and end in one of the following three digits (000, 250, 500, or 750) and if ANY other frequencies end in (125, 375, 625, or 875) use Plan 4.
mam1081
Next to a scanner...
Try Plan 1 - I know there are some freqs in there that don't agree with that type, but while running Trunker on that system, I don't think I remember seeing any of those freqs in there. That would be considered a "splinter system". You have a "standard" system in Edmond. Try listening with Plan 1 - if you think you are missing conversations, plug in all the freqs for the system and just scan it regularly (trunking, just not CC Only, or just conventionally (lock out the Control Channel)).
Good Luck.
