CDM 750 Programming Question
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Can the audio Compression be turned off or ratio changed in the programming?
In the Advanced tab of each personality, there is a drop down for Compression Type. You have your choice of Disabled, Full, or AGC.
So the answer is, yes, you can disable compression if you want, channel by channel.
Also, in Radio Configuration on the Basic tab, you can enable or disable the Audio Processing Filter. That may or may not help your situation. But that is for the entire radio, and not just one personality.
(Version R06.12.09 of HVN9025 Professional Series CPS)
SteveC0625
I gathered up some more of my notes on audio issues for the Pro Series late last night.
Recommended initial audio settings to avoid tinny sound:
Radio Configuration --> Basic tab: Uncheck the Audio Processing Filter
Conventional Personalities --> Advanced tab: Disable Compression and Expansion
Still on the Advanced tab: Select “De-emphasis & Pre-emphasis”
Do this for each personality where you are having audio issues.
Search tags:
The Professional or Waris Series of radios includes:
HT750 HT1250 HT1550
EX500 EX600 EX560 EX650 PR860
CDM750 CDM1250 CDM1550
HT1250LS+ CDM1550LS+ CDM1550LS
It may be helpful to search using wildcards.
If someone asks a question about one model,
the answer usually pertains to most, if not all.
They are all programmed with HVN9025 CPS.
W4TOY
Owensboro, KY
Thanks to all who responded. I'll pass along this info to the guy that set it up for me.
I am using the radio as a link transceiver on a local repeater. The radio works great, but the compression is a bit too much.
pddispatcher
And with that we got it fixed and working/sounding excellent.
Thanks for the help guys!
