CDM CDM Minimum volume
K4SPB
Is there a way to adjust minimum volume in professional CPS 6.12.05? I'm using a couple radios for a packet station and want to be able to turn the volume out of the front speaker off. I've adjusted a setting like it on ASTRO25 CPS so just wonder if its available on these and if so which tab is it under?
Thanks in advance.
K4SPB
Yea I’m connected to the rear so already have flat rx audio set up.
I finding more RR threads on this than my initial search now and it looks like this is not an option for the cdm unlike my initial research led me to believe. I wanted to keep it connected just turned all the way down so I could turn up to test. Guess I’ll just pull the head and unplug. Thanks.
davidgcet
get a micro toggle switch and put it in line with one speaker lead. flip it off for no audio then on if you need the local speaker. we did this many times with moto radios, though i cannot for the life of me remember how much room a cdm had in the head. but it can be done, even if the switch won't fit inside you can extend the wire out to it.
