CDM1250 CPS-Can't Read Codeplug
62Truck
Ordinary Subscriber
Ø
Check the COM port, is it the right one?
The CDM series programs best via true serial port, Motorola RIB and cable. RIB-less units may or may not work and typical brick radios.
Also, USB to serial converters usually do not work.
More info on your programming setup is needed to better diagnose the possible problem.
To be honest with good aftermarket RIB-less cables I have never had a problem programming a radio.
jfab
Broomfield/Aurora, CO
So I got a new RIB and cable from a local Moto shop today. I attempted to read the code plug again and it gave me an "unsupported model" message.
any ideas? thanks!
any ideas? thanks!
earlier cps 6.04 will say unsupported model it means the same thing as codeplug too new for the cps. very good to hear it will now communicate successfully but im afraid theres only one way to go from here and that is upgrade
