Cdm1250
ap2743
Hello,
We have a CDM1250 hooked up to a power supply in the station. When we transmit we get a double beep and some transmissions go thru and others do not. Could there be a qiuck fix for this or is a bigger problem that a tech needs to bench it?
XTS3000
Sounds like a low battery beep. I suggest you get a regulated power supply and one rated to handle the power needs of the CDM1250.
Same thing happens to my CDM in the car is I use it with the car turned off and the battery voltage drops below around 12V.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hello,
Is your CDM1250 a 25 watt model or 45-50 watt model? Frequency range? If you don't know, please post the model number - should start AAM25 - it will be on the bottom of the radio.
Also, are you using a Motorola power supply or after market? If Motorola, let us know the model number of the supply, please. Should be 3 letters, 4 numbers, and at least one letter on the end. If after market, let us know the amperage capacity.
It might also be helpful to know if you have just an AC to 12vdc power supply, or if the supply involves batteries and possibly a UPS.
The CDM family of radios is pretty robust so in cases like yours, it is normal to check outside the radio first.
RKG
Boston, MA
Take the nominal RF power output of your radio (in watts); divide by 10 (to get amps); multiply by 3; and that is the minimum size power supply you should use.
gary123
nice rule of thumb math, Ill quote it :) and take credit too LOL
RKG
Boston, MA
I have no creator rights; this is a rule of thumb that has been around since cans and string and was taught to me, er, a long time ago.
com501
That rule doesn't work with my 2-channel 60 watt dynamotor rig.....
