So here's the scoop - I am trying to program my CDM1550. I have an HT1250 I have been using for a while and I program it with a Windows Vista and Windows 7 computer through a USB to serial port adapter (one I got at Radio Shack, gigaware if I remember right is the company). I got the same kind of serial cable for my CDM radio - has an 8 pin RJ-45, only 4 of the pins are used.
Neither the Vista or 7 computer will read the CDM.
Next I tried a Win98 computer that has a real serial port on it. After working out the software that wouldn't read the CDM either. I tried my HT1250 to verify that the set up would work and no problems there - it read the HT1250 just fine.
Every time I try the CDM I get an error message about not being able to open the port.
Another note is the CDM has a remote kit on it, the faceplate isn't on the body.
CPS version is R06.12.05_AA.
There is one zone and one channel on the CDM. I verified the functionality of the radio through my service monitor and it checks out great. So that part works. It is just the communication between the radio and computer.
My only two thoughts are the version of CPS on the rig is newer or the cable isn't correct. The cable is new, Kawamall for the CDM radios. A friend of mine says if the CPS version won't work there would be another message than the port availability I am receiving. Can anyone verify this?
Any other ideas?
Any other ideas?
