Cdm1550 will not turn on
nicholas9543
Usa
I have a cdm that I bought hoping to fix for myself (got it cheap). The unit does not power on. Upon using a dmm in line to measure current. The current spikes from zero when the power button is pressed or ignition feed is tripped. Current is .16 amps, it will stay that until the main power is removed. I'm getting source voltage (+) on both sides the spot where a fuse normally goes. Continuity is good at that spot as well. When the ignition or power is tripped the screen faintly displays blocks as pictured. Any clues?
Sent from my XT1575 using Tapatalk
