Hi All,
First of all let me thank all of those who share their knowledge with everyone.
I am having an issue that I am hoping someone has seen before, and can help me solve.
I have a Motorola Astro Spectra High Power with the W3 head VHF. The radio has been used mainly for 2 meter amateur use on analog and digital, as well as listening to local analog fire departments and a P25 trunked police force.
A while ago, the radio suddenly started acting funny. When I would key the radio to talk, it would immediately shut the radio off (no delay or warning just instant dead on PTT). I hadn't done a reprogram or anything except turn it on and off when I would get in and out of the truck. Also, there were no error codes on the screen at startup or when it would shut down. At first I though it was a power supply issue from my battery to the radio. That proved to be fine. I then brought the radio in the house and put it on my Astron 50amp supply, and still the same problem. Shuts off immediately upon pushing PTT.
Thinking it is a fuse issue, I checked all fuses inside and outside of the radio with all being fine. As I was tied up with other things I put the radio aside and am just now getting back into working on it.
I tried to put in the original code plug that was in the radio when I got it, and still acted the same. PTT -> radio shuts off.
I went into the Astro Radio Tuner program and read the radio. Going into the high power adjustment, I click on the PTT button (expecting it to shut the radio down), and it transmitted just fine. 106 watts going into the service monitor. So definitely not a power supply issue. Was showing about 23 amps on the power supply. Same results on the middle and low power with obviously lower current draw.
Scratching my head, I moved each soft pot for power down 1 level and programmed into the radio. Rechecked the PTT on the mic and instant shut down.
I also checked the Oscillator alignment and was -15hz. Pretty close I'd say.
I by accident when going to turn the radio back on with the left button on the top of the HHCH, I pressed the PTT and the radio came to life. I then shut the radio off, and held the PTT down, allowing the radio to start up while holding the PTT down. Radio started transmitting fine at proper power output. Release the PTT and press again, and radio shuts off. WHAT?? It was just transmitting~!
I then turned the radio back on and was just going to put it on the back shelf for now and use it as a very heavy scanner. As I went to leave the room for the night, I started to disconnect the radio, forgetting that it was still on. I pulled the main power cord out of the radio, and all of a sudden heard the local fire department getting dispatched out. WHAT???? Power cord is in my hand. The only thing that was still connected was the ignition wire + and the coax, which I am assuming was keeping the radio alive.
So long story short, I am at a loss as to why the radio would shut off. It is obviously not a bad PA as it puts out full power when using the tuner software and when starting the radio up with the ptt held. When the radio is turned on the normal way, shuts off as soon as the PTT is pushed.
Is there something that I have missed? Really like the radio, but would like it even more if it would transmit and not just receive.
