eportel6607
Hi guys,
Trying to connect a CSI TP-154 repeater community tone panel to two CDM 750 UHF radios. This is the first time I've attempted to connect a tone panel to a CDM series radio and I can't seem to get thing working right.
The tone panel (TP-154) requires connections that I'm hoping will be accessible from the 20 pin accessory connector.
The connections are as follows (on the rare of the TP-154):
TX Audio -> connected to Pin #2 of the transmitter radio
RX Audio -> connected to Pin 11 of the receiver radio
PTT -> connected to Pin #3 of the transmitter radio
Sub Tone -> connected to Pin #5 of the transmitter radio (used to inject the pl/dpl tone into the TXer)
RX COS -> connected to Pin #14 of the receiver radio
Gnd -> connected to pin #7 of both radios
I programmed the CDM receiver radio with the necessary frequency and carrier squelch and pin #14 as Carrier Squelch Detect. I also set in the Accessories tab the RX audio source to RX Flat audio rather than Mic All the functions of the receiver radio appear to be working correctly. I set pin# 14 as carrier detect (carrier squelch) rather than PL/DPL carrier detect because the tone panel should be doing the decoding. This radio seems to be working fine. The tone panel is detecting the DPL that I'm encoding with a mobile radio and making the transmitter radio transmit.
The transmitter radio has been programmed to the best of what I can think might work for this application.
The tone panel should be passing the audio from the receiver out of the terminal marked "TX Audio" and I patched that into pin #2 on the CDM because this is marked as "mic audio in" (according to this data: HT750/1250/1550/PRO5150/7150/9150/GP320/340/360/380/ GP318/338/GP640/680/1280/CDM750/CDM1250/CDM1550,etc.) . There is no audio at all being passed to the transmitter radio from the tone panel. So I'm not quite sure if this connected correctly but I also tried connecting this "TX Audio" to pin #5 "TX Audio input" and still no audio. Now I'm hoping that the "Sub Tone" can be connected to inject the sub tone into the transmitter and I think that works as it's connected to pin #5 on the transmitter and I can hear the DPL tone whur sound, so I think this is the correct location for this connection.
Anybody know of any documentation of proper configuration of two CDMs connected to a community tone panel repeater controller?
Or do have to have make some connections inside the radio?
When using this tone panel controller with a Maxtrac (5 pin logic board) some of these connections needed to made inside the radio.
Thanks for any help guys
Chris
Chris
