Central Oregon Wildfires
kd7jfv
Bend, Oregon
Here's a list of frequencies that I've had activity on since the start of the wildfires in Central Oregon in case anyone is interested.
122.7500 NIFC Air 122.75
122.8500 NIFC Air 122.85
122.9000 NIFC Air 122.9
122.9250 Local Flight Following / Logistics
123.0250 NIFC Air 123.025
123.9750 Redmond Air Tanker Base
132.3750 OR03 Primary
133.3250 OR03 Secondary
133.8250 OR03 Tertiary
151.1750 Grizzly Repeater 162.2 PL
151.1900 Sugar Pine Repeater 162.2 PL
151.3400 RED Net 156.7 PL
151.3850 Fire Cache Tac 4 156.7 PL
151.4000 Fire Cache Net 1 Repeater 131.8 PL
151.4150 Fire Cache Tac 5 156.7 PL
151.4300 Fire Cache Net 1 Backup 131.8 PL
151.4750 Fire Cache Tac 7 156.7 PL
154.2875 Statewide Fire Ground 156.7 PL
154.3625 Jefferson County Fire NAC 107
154.9650 Crook County Fire Dispatch 131.8 PL
154.9950 Lake Chinook Fire Dispatch 162.2 PL
155.0250 Jefferson County Fire Ops 1 NAC 101
155.2350 AirLink 85.4 PL
155.8650 Jefferson County Fire Ops 2 NAC 123
159.2625 BLUE Net 156.7 PL
163.1000 NIFC Wide 2 CSQ
163.7125 Project 1 100.0 PL / CSQ
166.7625 Tac 1 CSQ
166.8875 Tac 1 CSQ
167.1375 Project 2 CSQ
167.6500 Tac 2 CSQ
167.7000 Deschutes Local Flight Foll. 103.5 PL
168.5500 Smokejumper Primary 123.0 PL
168.6125 Project 3 225.7 PL / CSQ
168.6500 National Flight Following 110.9 PL
169.1250 Project CSQ
169.2875 Air-Ground 61 CSQ
169.9750 Grizzly/Drake/Viewpoint 131.8 PL
170.4750 Central 103.5 PL
170.5000 Wolf/Aldrich Mountain 131.8 PL
170.5500 Round/Pisgah/Wolf 131.8 PL
171.2625 South 103.5 PL
171.4750 North 103.5 PL
172.6500 Aldrich/Direct/Hampton 114.8 PL
173.8375 BLM Grizzly 173.8 PL
MikeyC
Utica, IL
There is also initial attack traffic on the OR State Radio Project (at least here in Bend on Site 110) for stuff in Deschutes County.
Initial dispatch on 9151 (Deschutes County FD Dispatch) with initial attack traffic on 9152 (Ops 2), 9153 (Ops 3), and 9154 (Ops 4). Today on a fire in Redmond they mentioned switching all of the traffic to "BLM Tac" which I'm apparently too far away to hear :D
Baker845
Oregon
BLM has a few tac channels, but they are simplex and you have to be within 5 miles to hear.
turbogofer
In addition to that great list, I've heard activity on these channels this week.
151.2800 ODF Net 3 Repeater 162.2PL
153.8975 Statewide On-Scene Command Post A 136.5PL "Structure Blue"
168.4000 National Air Tactics 3 CSQ
168.6000 NIFC Tac 3 127.3PL
173.0375 NIFC Command 12 127.3PL "Sisters Communications"
410.7750 NIFC Logistics 5 110.9PL
Be sure to go to the Nationwide Frequencies section of the database, under National Interagency Fire Center and plug all those freqs in. I've heard activity on quite a few of them.
Baker845
Oregon
Are these fire's burning on ODF, USFS and BLM Lands?
Fishfreak
Portland oregon
so im in SE Portland, is there an antenna I can buy for my portable sds100 or would I need a house mounted antenna ?
Fielder3
North Willamette Valley - Oregon
Since you posted in this folder for wildfires, I assume you were looking for VHF stuff like; USFS Mt Hood, Oregon Dept of Forestry, Multnomah County Fire, etc. In SE Portland, you should be fine with the SDS100 antenna for 30-40 mile range to get the Tri County area including Clark County 800. If you want some DISTANCE like East Mulnomah County up the Columbia River Gorge, down south towards Marion County, then you might.. and I say that loosely, want a Discone type multi band roof antenna with a coax feedline into the house or garage/shed. There are lots of Discone type antennas on eBay and Amazon for sale at decent prices. RG58 RG6 coax cable works good for shorter cable runs, LMR400 works better for longer runs with low signal loss. The key is identify what your listening interests are, and range you want, then experiment with different antennas. I've owned a scanner(s) and different antennas since the mid-1970s and still mess around with antennas even today.. and each time I happen to move.
Check out Scannermaster.com and look up the antenna tab on top.
