Cessna Citation having mechanical problems near Rocky Mountain Airport
natedawg1604
Colorado
Within the last 20-30 minutes Rocky Mountain Airport activated a "Code Orange". (Primary Comms are on the DTR Rocky Mountain Airport Emergency Channel, TGID 1519). Evidently a Cessna Citation aircraft is having mechanical problems, they have 2 souls on board with 5000 Lbs of fuel. The aircraft is dumping most of it's fuel before landing, which is expected to take about 1 hour. Due to delay, all North Metro Fire & Medic units went back into service, they will be re-toned prior to landing attempt.
natedawg1604
Colorado
So, the aircraft is now planning to land on runway 29-right (it made numerous "test" passes in the last few minutes). The aircraft was asked to turn off landing lights so tower could get a better view of the wheels.
abqscan
DataBase Administrator
Moderator
AOA
Weird that it didn't divert to DIA.
natedawg1604
Colorado
Update: the plane has landed safely, all North Metro units going back into service. As an aside. I've been hearing call signs "R-59" and "R-65", are those "regular" North Metro Fire units with special gear for airport emergencies?
MikeyB
Centennial, Colorado
The airport itself operates a crash rig - ARFF 55 to go along with the North Metro rig, numbered 65. Check out the 5280fire.com website. Not sure about '59'.
rfburns
Aircraft callsign sounded like Foothills 444. Problem was that the landing gear was cocked about 20 degrees to the side.
