CFB Trenton exercises
Saint
Fort Erie Ontario Canada
I watch these military aircraft every day doing their exercises, around CFB Trenton air base and was wondering what frequencies they would be using for plane to plane communications. I never pick them up on frequencies.
Saint
IdleMonitor
The Ottawa Valley - Eastern Ontario
Saint
Just do a search in the military band and listen for there call signs. They must be there somewhere. I've heard the BRMA ones before while at Petawawa.
I'm sure you'll find them at some point.
Saint
Yea, I have been doing that for a while. Can't seem to find them, maybe too far away and to close to the ground??.
Saint
Napalm
Calls provider
Lake Co, Ind
Use SDR# and the Frequency Scanner plugin. You can scan the whole of UHF Milair in about 7 seconds depending on your settings.
I've been using it for the past couple of days and found frequencies I would never have discovered using my 8 conventional scanners in search mode.
Saint
I have been using the fast scanner plugin for months, Thanks for the reply.
Steve
nodak1crdet3
Detroit, MI
Hi Saint.
Try 254.450 for A/A. I had TRKR 91 & 92 C-130's thru here 11-18-21 using that for A/A.
232.100 TIGER SAR Ops.
268.000 Trenton CP Ops.
Chuck in Detroit. / NODAK 1
moonbounce
For plane to plane they also could be using frequencies in the 138 Mhz to 144 Mhz band, in AM mode, for plane to plane I would expect them in this area. Scan in 5 khz steps.
