Changes listed but not highlighted
randybcd396t
Los Angeles
In California, there are 2 statewide changes listed for the past 24 hours where nothing is highlighted.
Department of the Highway Patrol (CHP)
This shows last change of October 3, 2010 at 5:23 am. The history shows 2 frequencies updated but nothing shows up as highlighted in green to indicate changes in the past 24 hours.
United States Forest Service
This shows last change of October 2, 2010 at 6:11 pm. The history shows 2 frequencies updated but nothing shows up as highlighted in green to indicate changes in the past 24 hours.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
A possibility may be that it may be something as subtle as the addition of alpha tags to that freq.
The freq's themselves may not have changed, but you may have alpha tags where none were published before.
randybcd396t
Los Angeles
That may be. These systems are pretty large so without highlighting it is difficult to know what to update to keep my scanner current. If they were smaller systems I would just redo them.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Perhaps location data was updated for the AWIN sites in anticipation of the Home Patrol-1 future usage. Every edit detail is catalogued and timestamped.
Anything different show up while scanning?
zzdiesel
Kennett / Dunklin Co, Mo.
Oh I'm sure the updates are there, but the database is so big that it is hard to tell what is new. I have my radio set to scan and not search. So I see no changes.
burner50
The Third Variable
NC Iowa
If it wasnt highlighted, it was a minor edit that didnt change anything regarding the way you monitor the system...
This means DB organization, spelling, tagging, etc...
randybcd396t
Los Angeles
Thanks...
EDIT: can you confirm that location data is not considered a minor edit?
loumaag
Silent Key - Aug 2014
Katy, TX
Thanks...
Actually, I think that changes of location would highlight the line item. I am not sure if changes to subcategory or talk-group group locations causes highlighting. The reason is, I am not sure that either subcategory or talk-group group highlight ever and are flagged when new only. However, I am sure that the history reflects what subcategory or talk-group group was edited by name.
