Back story: Trying to reduce the number of unused zones on our aircraft radios. We have three aircraft, and each one has a Triband and Dual Band Radio that is programable via the APX soft wear. Each aircraft has assigned Unit IDs for different trunked systems (Our State Sys, Neighboring State Sys. Shared County Sys. Neighboring County Sys. (The primary State sys and the Shared County Sys use the same IDs the Neighboring State, and the Neighboring County have their own assigned ID per radio.))
I have programed one of the Triband radios to the new code plug format we want to use. I did a drag and drop to the other two Triband radios and all three Dual Band radios. I've done this in the past have been able to change the unit ID numbers to the proper assigned aircraft radio in the past however; while doing it today, the unit ID box is not allowing me to edit the unit IDs.
In hopes to anticipate questions, we are using APX R31. The Moto Log In is from a former mechanic, no longer with our team. ASK programing is not checked in CPS.
Anyone have ideas as to why I'm having this issue.
