Charging a XTS3000
ob123
NJ
I was told that you can charge a XTS in a HT1000/MT2000 charger. When I charge my battery over night i wake up and the charger is blinking red. Dose anyone know why this is happening?
K2JLX
FN21
Wrong chemistry? what battery are you trying to charge in the jedi charger?
ob123
NJ
I am charging the XTS3000 Impress battery in a IntelliCharge 2 charger
N4DES
Retired 0598 Czar ÆS Ø
South FL
Is it a Li-Ion battery impress battery? If so it may not like it.
What is the model # of the battery?
ob123
NJ
It is a 7.5 lithium-ion battery
kit # nntn6034a
Devils4121
I also have the same problem with my XTS 3000 and charger i dont know why....
SLWilson
Ohio
Impress
I have the Impress battery AND charger.
If I put a battery in it that isn't dead or nearly dead, it flashes YELLOW for a while and then goes back to green.
I've only had it flash RED a couple of times when I put the battery in it, but that usually clears up & goes to steady RED....
Steve/KB8FAR
kc4wwu
Camden County, Georgia
Bad Battery
If you put it in the charger, and the battery flashes Red and keeps flashing Red, its usually an indication of a bad battery.
Devils4121
im good friends with ob123 and he has the same problem....how long should we wait
N4DES
South FL
Steve/KB8FAR
Look on the bottom of the impress charger and it will answer all of your questions.
Josh
Auburn Hills, Michigan
If you have and use IMPRES batteries, you should use the intended impres charger in order to make use of all the benefits the IMPRES system is capable of, aside from just being another battery when used in an ordinary charger.
-Josh
Astro25
Chicagoland
To echo J.O. here (Josh) -
*Do NOT* initaliaze your Motorola IMPRES(tm) batteries in a non-impres systems charger. It will mess up the 'Smart Battery' data that is displayed (this only applies to the ASTRO25 series Two-Way radios)
Also - if you only charge your impres charger in impres chargers, it extends the factory warranty by approximately 3 months.
