Good day,
Got his cheap antenna: https://www.tme.eu/Document/ab28b11ed5a07f3d86b2cbf91b5e11e7/433M-ANT824.pdf
Trying to use it as a way to check my measurement-taking setup and equipment.
- NanoVNA calibrated at S11 port for 50 ohm
- Plastic stand for the antenna with good clearance around it
- measured at heights of 1.2m and 1.65m above the ground
- i was standing another ~ 1.5m away from the antenna with the VNA, reading it.
433.8 MHz: ~ 3.3 - j10 ohm
441 (+/- 2) MHz: ~ 29 (+/- 5) - j1 ohm
There is no official SR Passives contact info that I could find, so I am asking here: what is more likely, the antenna really is not very well tuned or my measurements are skewed ?
