Cheapest PC controlled scanner...
loumaag
Silent Key - Aug 2014
Katy, TX
LarrySC said:
A used PRO-93/2053 with WIN-93 software. Not sure about E-trunk.
The Pro-93/2053 is not able to be controlled by a PC. It is only able to be programmed by a PC.
Philadelphia:
The Pro-2052 can be controlled as can most of the Uniden and Uniden built RS models. Look for a 9 pin DIN on the radio as the first hint that it can be PC controlled. You then have to confirm that your copy of the Trunker (or ETrunk) has the proper code to be able to instruct that radio to do what you want.
Edited: Just realized you asked for digital radio. That narrows the field considerably. Basically there are no cheap solultions available. :shock:
kgasso
Grants Pass, OR
Philadelphia, if you find any others, please share the model numbers... I'm always interested in more crap to hook up to my already overworked PC :)
But seriously, it would be useful with a custom interface for my in-car entertainment (mostly music) PC. I'd love to have a scanner hooked into that instead of one ghetto-mounted to my sunvisor :p
