CHIRP query not able to pull up entries
Verruckt
I'm using CHIRP to query the db to gather frequencies. However I'm not able to get Missouri Public Safety frequency info, as I'm only able to search by zip code. Does anyone know a way around this? Trying to upload to my baofeng radio to scan Highway Patrol. Any help is appreciated.
Verruckt
Are they on a trunked system?
Forgive my ignorance.. I’m not sure what that is. When I manually search the database, I’m able to see the Missouri public safety grouping; and within that the Missouri Highway patrol. But using CHIRP to query the database, I don’t seem to be able to find that section.
Querying from CHIRP, I only get the option to search by zip code, which doesn't pull up the data that I'd like to upload to my radio.
Is there another way to do this within CHIRP?
dave3825
Suffolk County NY
What radio do you have and what exactly are you looking to have chirp import? Post a link in the database. The link you already posted has low band, vhf, uhf and links to trunked system and does not specify the users you are interested in.
nd5y
Wichita Falls, TX
It's a digital trunked radio system.
Your Baofeng cannot receive digital voice signals.
Your Baofeng cannot track a trunked system.
MO SHP also uses VHF low band (42 MHz) as a backup. Your Baofeng cannot receive VHF low band.
In some areas MOSWIN uses 700 MHz and 800 MHz. Your Baofeng can't receive those.
You should have bought a scanner.
CHIRP probably won't import frequencies that each radio model doesn't cover. I'm not sure about that. If it does, then you still won't be able to upload to the radio.
EAFrizzle
Bond. Ward Bond
SE de DFW
CHIRP will not import any frequency or mode that the radio doesn't have.
For statewide analog systems, like some Texas state agencies, that the radio will handle, you'll need to import from the website to a .csv file. Then you can copypasta to the image.
