Baofeng Chirp question (programming)
escissorhand
I am trying to peogram a Baofeng UV-82 with chirp to listen to (and later transmit) a local repeater the particulars are...
Frequency- 147.330
Tone. 123.0
Offset-+0.6
My problem is that I can receive all communications from the repeater on an old police scanner, but only a receive light on the
handheld.
My problem with Chirp is that when I try and program the info, ie (frequency. tone, crosstalk, offset etc there is always a tonesq.
I cannot find anyway to disable tonesq. I have been told that my problem may be the tonesq, have watched all videos,they only
cover correct cables and copy and pasting. checked outChirp, cannot find a way to disable the tonesq feature.
please, any suggestions would be so appreciated.
sallen07
Rochester, NY
Sounds like the repeater requires a tone to open it but is either not transmitting a tone or is transmitting a different tone. Try setting the "Tone Mode" to "Tone" instead of TSQL and see what happens.
You should be able to determine what (if any) tone is being transmitted with your scanner. Set the tone mode to "Search".
nd5y
Wichita Falls, TX
Don't rely on youtube videos to learn anything about Chirp.
Look at their web site. Documentation - CHIRP
Specifically Memory Editor Columns page. MemoryEditorColumns - CHIRP
Go to the View menu, check Hide Unused Fields and uncheck Smart Tone Modes.
Set Tone Mode to Tone. Not TSQL.
Set Tone to 123.0 or whatever tone you need.
ToneSql
and Cross Mode should then be blank.
ko6jw_2
Santa Ynez, CA
First of all, not all amateur repeaters use CTCSS on the output. Also, you don't need CTCSS decode it to receive. Split tones are very rare on ham repeaters and many radios can't do them (none of my Yaesu radios can). Baofengs can do split tones interestingly. Since you aren't licensed yet, just program the output frequency of the repeater with no tones. When you get your license you can add the input tone.
Another step would be to find the web site for the club that owns the repeater. They usually list the tones on the web site. Last, get in touch with them. If you want to get your license, they can help you.
Finally, ditch the Baofeng and get a real radio.
escissorhand
Changed the tone mode to tone at 123.0 and the repeater comes in loud and clear. you people are great, I have pretty much figured out
that youtube is only good for copying and paste and other computer info. not specifics about Ham radio.
I do agree about Baofeng, but it was just a way to getting familiar with things like chirp and some of the basics that are not covered
in the technician study. I have been in touch with the local club, but because of covid they are not very active right now.
I can now listen to their virtual meetings when I am away from the scanner. While waiting on test I am studying for the general. Again, many thanks
