Baofeng Chirp & UV-82 - Firmware Message Disappeared
fake_out99
Hi Guys,
Had a weird issue happen when trying to program my Baofeng UV-82 with chirp. When I first received the radio I downloaded the radio image using chirp, saved it as my reset file in-case anything with the radio ever went wrong. Firmware Message 1 on chirp read N82-33. Firmware Message 2 was blank.
Copied the image file, programmed in my channels per usual and uploaded the image back to the radio. No problems. A couple days later I wanted to change some channels. Opened up my image file with the channels, changed a few channels and tried to upload to the radio. I get this error message:
I tried to upload the reset image I had created for the radio and received the same error message.
I was able to download a new image file from the radio. Now Firmware Message 1 is blank and firmware Message 2 is also blank. I'm assuming that is what is causing my error message. Anyone know how or why this happened? How can I get the original image with Firmware N82-33 back into the radio?
