I would REALLY suggest avoiding the 100 ft of coax run! But I think I have completely misunderstood something because your most recent concerns aren't making sense to me. I've made this diagram of my assumptions based upon your descriptions thus far. Tell me what's not right... View attachment 83538
That diagram is correct in all ways. My concern lately was after thinking about this setup, not being able to run that ground wire because of the height. I’ve seen where the ground wire shouldn’t be so long as it will began to act as an antenna. But now I see I don’t need that wire at all.I would REALLY suggest avoiding the 100 ft of coax run! But I think I have completely misunderstood something because your most recent concerns aren't making sense to me. I've made this diagram of my assumptions based upon your descriptions thus far. Tell me what's not right... View attachment 83538
That diagram looks doable when I stare into my yard. If the ground needs to be between the choke and the radio, I can come up with something to make that work. It’s a rental house, so I can’t do too much altering or tapping into electrical stuff and being in the military, I’ll be moving in 3 years too so this isn’t “permanent”.If the OP can get the height drawn here it would work well. I would however attach any ground wire on the radio side of the choke balun so it doesn't introduce noise up to the antenna.
Look closely at the pics of the MyAntennas EFHW-8010P and you'll see the wing nut for the ground wire that I referred to in the diagram as "Ground wire from wing nut on transformer to ground". That ground connection is most likely on the radio side of the balun / transformer. Here is the web page with the pics - EFHW-8010P
Got it up, made a couple contacts on 40 meters. First one 549 miles away in New York, a second in Tennessee at 1,254 miles. I guess that means it works. SWR is about 2:0 on 40meters and 1:1 on 20 meters.
I am down around New London, CT. Slightly Northeast in the country.Where are you transmitting from? I have a remote HF rig near Boston and it looks like you might be within range.
That would be nice, I have yet to hear any other station around me yet, but I have my ears out for it.Pick a band that you can hear other New England stations on, pick a freq/time and let me know. It would be fun if we could make a contact.
??? - You should be hearing plenty of other "1 land" and "2 land" hams if you listen at the right time, band, and mode (phone, digital, or CW if you're so inclined). Try 80M in the morning or evening. Or 40M nearly anytime in the daylight. Are you running any digital modes (FT4/8, PSK, JS8)? They are busy nearly all the time. If you're searching only for SSB phone the number of stations will be much more limited. Another bonus to running digital on FT8 / FT4 / JS8 is that you will be able develop very specific data regarding how your antenna is working on each band. Rather than a "59" report on every QSO such as you get with phone contacts, you'll have a specific RSSI from every station that hears you.That would be nice, I have yet to hear any other station around me yet, but I have my ears out for it.
