i made inaccurate statements about caltrans ?
the freqs i posted are from the codeplug that was used in all of the caltrans mobiles and portables-
so if you think its incorrect? ... go read any radio (mts2000, stx, xts3000, xtl2500, xts2500) in district 4 and you will find what i posted is accurate
2B13 WPBH806 9/9/2008 has control freqs of 856.7625 858.7625 859.7625 857.0875
ULS Application - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked - 0003573124 - CALIFORNIA, STATE OF - Frequency Summary
click on frequencies
2B14 WPCQ369 9/9/2008 has 857.9875 858.9875 859.9875 857.1625
ULS Application - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked - 0003573598 - CALIFORNIA, STATE OF - Frequency Summary
each set of new frequencies added became THE data channel..because somebody goofed and made the new rebanded freq the control channels INSTEAD of the highest of the 4 control freqs
thats from the codeplug - so you can debate that all day - thats whats in their radios -if it's wrong then about 287 radios need to be reprogrammed AGAIN
the north trunker controller itself had to even be reprogrammed because the codeplug had incorrect control freqs-so every 3rd day nobody would be able to use it - so the controller got reprogrammed
in motorola codeplugs you only enter 4 control freqs and thats whats in the codeplugs
age doesnt mean inaccuracy ?
LOL do you really think that a drawing of chp in 1987 is accurate? when there are versions as little as 1-2 years old?
I can count at least 12 paths missing from the microwave path map that have been put up since that doc was made- not to mention the paths that no longer exist (dot marysville to bald mtn yolo) been taken down almost 2 yrs now thats a small sample
as far as this document - do i need to go page by page and point them out for you > ?
appendix existing freqs and colors -
willows and oroville are are NOT on the teal
stockton is NOT on the pink
dublin is NOT on the khaki
pretty bold statements huh
the scan rates were so small on the future freq maps you cant enlarge them to even see what freqs they are- all it does is pixelate it
another drawing uses incorrect info from the EXISTING drawings to coordinate future 700 freqs
same for other old drawings
old outdated drawings from 20 years ago - look on each drawing and it has the date on it -nothing "bold" about it -
i did NOT post a spreadsheet about chp
- somebody else posted it -
it was an xls sheet that had the freq load that was used in each division and thats what i told people to refer to if they wanted to see the new rptr freqs - each division has them at the bottom of the spreadsheet page for each division
i dont "know" them to be "true"or "false" .. i "read " them and stated obvious and glaring errors about each item
hopefully the corrections and updated drawings will be edited and replace the old and outdated info and it will be an informative and accurate document
if you want the new freqs and pls - as i said - the division xls sheet has everything you need - and its accurate it has the new BLUE1 and BLUE2 for each division and their PLs
and each color with a 2 suffix is the new freq .. ex valley has brown2 gray2 wite2 at the bottom of that excel sheet its what is loaded in each ge ranger
if you have never seen any of these drawings or tables you might think its great and amazing - if you have seen them before .. it would make you ask.. which i did..
why are such old drawings used and such incorrect info disseminated in something ?
trying to get a more accurate doc is what i was aiming for.. with my statements
