City of Fayetteville NC fire missing from sds100 data base?
sunnydog1
So I have everything working correctly in a favorites list but I've been playing around with the database because I'm getting a GPS for when traveling and noticed that the city of Fayetteville fire seems to be missing. I selected the following service types fire dispatch fire tac and fire talk. I've also updated the database. You can enter the 28304 zip select the Durham Fayetteville system and scroll through departments and city fire is missing. Maybe I'm doing something wrong any suggestions would be appreciated.
wtp
Port Charlotte FL
way down the page.
is it this one ?
Fayetteville Fire
DEC HEX Mode Alpha TagDescriptionTag
13631353fDFayFD 13631FireFire-Tac
136323540DFayFD Disp 1Dispatch 1Fire Dispatch
136333541DFayFD Disp 2Dispatch 2Fire-Tac
to save time hit control and F and then (13631)
Chris0516
Pittsboro, North Carolina
Fayetteville Fire
DEC HEX Mode Alpha Tag Description Tag
13631 353f D FayFD 13631 Fire Fire-Tac
13632 3540 D FayFD Disp 1 Dispatch 1 Fire Dispatch
13633 3541 D FayFD Disp 2 Dispatch 2 Fire-Tac
13634 3542 D FayFD 4A Tac Ch. 4A Tactical Fire-Tac
13635 3543 D FayFD 5A Tac Ch. 5A Tactical Fire-Tac
13636 3544 D FayFD 6A Tac Ch. 6A Tactical Fire-Tac
13637 3545 D FayFD 7A Tac Ch. 7A Tactical Fire-Tac
13638 3546 D FayFD 8A Tac Ch. 8A Tactical Fire-Tac
13639 3547 D FayFD 9A Tac Ch. 9A Tactical Training Fire-Tac
13644 354c D FayFD 1B Ch. 1B Fire-Tac
13645 354d D FayFD 2B Ch. 2B Fire-Tac
13646 354e D FayFD 3B Ch. 3B Fire-Tac
13647 354f D FayFD 4B Ch. 4B Fire-Tac
13648 3550 D FayFD 5B Ch. 5B Fire-Tac
13651 3553 D FayFD 6B Ch. 6B Fire-Tac
13652 3554 D FayFD Chief Chief Fire-Talk
13653 3555 D FayFD BatCmd Battalion Commanders Fire-Talk
sunnydog1
way down the page.
is it this one ?
Fayetteville Fire
DECHEXModeAlpha TagDescriptionTag
Yes but I'm talking about scanning the full database within the scanner.
trumpetman
Charlotte, NC
The coordinates for FFD are using the default location for the system which is centered over Durham (click on the subcategory details to see the map). I'll update the coordinates and you'll have to update them manually in your scanner or update from RR on Monday when Uniden does a systemwide database update.
Edit: Database has been updated. If you navigate to your favorites list on the scanner and edit the location data then you can update the coordinates manually. Enter 35.0796 for the latitude, -78.9325 for the longitude, and 20 for your range and that should match up with what FPD is setup for.
sunnydog1
Since it's working in my favorites list I'll up date the database Monday. Thank you so much for the help.
