Cleaning HT radios.
GlobalNorth
Fort Misery
A rather silly question perhaps, but what cleaning products does one use to keep their HT radio external cases, knobs, and keypads clean and occasionally disinfected?
a417
microfiber rag with warm soapy water. Disinfecting usually done with a lysol,clorox,whateverwasonsale wipe.
if they got really gnarly, they'd get the cases popped & parts soaked - but that was rare. Effective, but rare.
trentbob
W3BUX- Bucks County, PA
Good question and I know I'm going to be called wrong, I like to use Ethel alcohol spray very sparingly. Of course a good microfiber lens cloth. :)
K2NEC
NA
For the hard to reach places like the speaker grille I get a cup with warm soapy water and use a soft bristle toothbrush to clean with.
Plus all the previously mentioned methods.
I agree with Trentbob, I use denatured alcohol. It won't hurt the plastic or the screen. It's used/sold as a plastic cleaner, and even recommended for cleaning plexiglass. It will easily remove adhesive residue and even ink pen/markers.
I've also used Simple Green and a tooth brush to really scrub them down if they get nasty.
Armor-All will shine them up like new.
At work and for COVID safety, I use disinfectant wipes when the radio arrives and before we return it to the user.
Back in early 2020, Kenwood/EFJohnson released this document about disinfecting radios:
JVCKENWOOD is announcing the following product information.
In response to the COVID-19 pandemic, JVCKENWOOD is providing recommended cleaning and disinfecting instructions for Kenwood radios and accessories to assist with general hygiene guidelines set forth by the World Health Organization (WHO) www.who.int and the Centers for Disease Control and Prevention (CDC) www.cdc.gov.
General Cleaning
1. Remove dust and dirt from surfaces using a clean, soft cloth. If additional effort is required to remove dust and dirt, a non-metallic brush may be used to loosen dirt and debris.
2. Apply a 0.5% detergent-water solution (ex: natural detergent or mild dishwashing soap) or a 70-80% disinfecting ethanol* solution to a clean, soft damp cloth and wipe down all surfaces. If using a detergent-water solution, distilled water is recommended.
3. Dry all surfaces using a soft clean cloth paying close attention to terminals and connectors.
4. Inspect the radio to make sure no cleaning solution remains trapped near connectors or inside terminal cracks or crevices.
* The majority of commercially available disinfecting ethanol is diluted to a 70-80% solution. Please check the dilution ratio before using to clean/disinfect radio or accessory surfaces.
Ant9270
The Green Weenie
I use a light 80% water 20% goof off mix. Wipes everything clean, and leaves the radios with a nice shine afterwards. I've been using it for years on XTS, VX,APX. Never had any issues with decay or discoloration of the housings.
trentbob
I'm a big fan of Goof Off but I never used it in a communication Radio application. You know best but I would be very leery of Goof Off, it's a very strong effective cleaner. I guess that comes from the old days when I made a... few costly mistakes. :LOL:
Randyk4661
Garden Grove, CA
When I was in charge of the rental radios for the company I worked at, I used an orange (not the color) cleaner and a toothbrush. Wipe it down then use formula 2000(?) as a protectant. Again wipe with a clean dry cloth to get slickness off the radio.
After I was done, the radios looked new.
There are some really good citrus based degreasers that work well.
The Formula 2000 is a Armor-All type product and does a great job of shining up the radio. I sold off a bunch of my old UHF HT-1000s for a good price by spending the time to really clean them well. The Formula 2000/Armor All really makes them look like new.
And, yeah, wiping off the excess is a good idea, lest the radios get slippery and fly out of the hand.
clbsquared
Isle of Wight County
Lots of good advice has been given. I will add that I usually start with a soft bristle paint brush and remove any dust or dirt that’s accumulated in those hard to reach places. Like the grille, around the antenna and knobs. Most of the time, that does such a good job that I rarely do anything else. Unless there’s an obvious build up of gunk on it.
merlin
DN32su
I have always used a mild detergent and a clean fleece cloth.
The stubborn stuff usually comes of with 'denatured' (rubbing) alcohol.
Get the dust off first with like a new paint brush.
That simple green is a good mild detergent, but about anything will work.
Dawn liquid dish soap even.
Yep. I dilute it quite a bit and it's never ruined anything yet.
My work truck gets parked under redwood trees most of the time. The tannin out of the bark tends to leach out in the rain and stain the crap out of the truck. I've found that purple power is one of the few things that gets it out. I used to have a big 2 1/2 gallon jug of the stuff in my garage. I think I'm out and need to get some more.
