ProScan: Clicking Speaker Icon Mutes All Instances
fxdscon
¯\_(ツ)_/¯
I appreciate the suggestions. using the .bat route it will open the first instance but won't open the second until I close the first. Any ideas?
this is what I use for a bat file:
@Echo off
start "" "C:\Proscan1\ProScan.exe"
start "" "C:\Proscan2\ProScan.exe"
start "" "C:\Proscan3\ProScan.exe"
exit
This will start all named instances of ProScan and then close out the CMD window.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
@Echo off
exit
Thanks. After an hour of Googling I came to the same conclusion and was about to come back here and update.
KevinC
Encryption
Super Moderator
Well I knew how to do it in a shell script ("&") but had to look up how to do it on Windows. I think if you use the "start" command it will do what you want:
start "C:\ProScan\ProScan1\ProScan.exe"
start "C:\ProScan\ProScan2\ProScan.exe"
No, I haven't tested it. :p
Almost.
rodentkj
Snohomish Co. WA
As long as I don't use shortcuts it works fine, so I'll just keep starting each instance from the .exe in the folder.
Don't know if this will help you or not.
I use a program called Startup Delayer to control what starts up on it's own.
It's simple to add programs to start. And disable ones you don't.
Will often setup a few seconds of delay when when I have a series of the same applications starting upon boot.
I also find the GUI is a nice way to visually see what all is starting up.
It's got lots of "bells and whistles" to play with. Free edition is fully functional.
