Cloning F5061
JCCNAV
I am having problem cloning the F5061. I can read and get the radio information, but can not write.
CS-F3160/F5060 SW Rev 2.7, OPC-1122u cable, Com speed set to normal, brand new radio F5061
ab3ai
When you try to write to the radio what does it do or not do and are you getting a error message?
Need morei nfo....If you can read it you can write it. It has to send a command to read it so it is communicating. Have you tried to just read it and rewrite it with no changes ? I am guessing it is a newer version than the software you have. This will allow you to read it but not write it.
gmrsoutlet
Oswego, IL
You probably have a Firmware and Software version mismatch.
Icom is constantly updating this series with firmware enhancements. Along with them comes updated software. If the software version is out of date and you have newer firmware (or the opposite) they may not work.
Your Icom Authorized Dealer should be able to assist. (Hopefully you bought it from an Authorized Dealer). If not drop me a line and I can attempt to assist - but won't step on the toes of another Dealer if one is already in play.
JCCNAV
I get the no answer from transceiver error message.
I am trying to write new information.
SW Rev 2.7
Firmware Rev 1.2
gmrsoutlet
Oswego, IL
Current Firmware is 3.0 (you have a very old 1.2)
Current Software : 2.8
The Software version that you have (2.7) is supposed to be for radios with Firmware version 2.9.
Your radio needs a firmware update to get it to at least 2.9 to work with the software that you have. If you are acquiring this through official channels that official channel should be able to provide you the update.
I am an Authorized Dealer, but again, if you are working with another Authorized Dealer I don't want to take away a customer. If you are not working with an Authorized Dealer PM me and we can talk about getting you current.
